Had upgraded the OS to 8.1 WIN a few months earlier w/o any issues. Suddenly when I POWER ON, the display shows a back lit blank display and nothing is coming out. Had tried to recharge the battery desite the GREEN LED DISPLAY on battery.
SOURCE: My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
SOURCE: flashing battery icon
The machine is telling you the battery is not charging or is otherwise no good.
The battery for this unit is subject to a recall, if it has part #OU091 or W1435. This recall started in October 08. Go to:
http://www.dellbatteryprogram.com/
for more info.
Alternatively, bring your power supply to a Radio Shack, and make sure it is putting out the requisite 19V DC power.
SOURCE: Acer one AOA 150-1786 running Windows XP SP3 Home Ed.
Those signs are those of a dead motherboard, it is quite expensive to fix i would recommend to replace it with your dealer
SOURCE: system won't boot - show's green battery icon only
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
SOURCE: sager 5600d notebook computer not work
good observation. this may be ram fault. for proper solution over internet u have to be a techanician.
Perform an EEPROM reset:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
