Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
Loud pop, then no pic on set, replaced bulb ( 3rd time!!!) turned on set hear buzzing sound, no picture, tv trys to restart, over and over, still no pic then powers off. any ideas?
thanks
Emilio
Posted by habsfan on
  • 5 more comments
  • Bozz1 Nov 28, 2007
    Toshiba 52hm84 DLP buzzing sound no picture. Checked lamp, lamp had popped. After replacing the lamp, buzzing sound continued on start up, picture worked for a couple of hours, then I shut it off. The next day I went to use the T.V. no picture and a buzzing sound is all I get again. The T.V. does try to restart itself 7 or 8 times as stated in the guide if the picture does not come on, with no resolve.
    What is my next step?
  • Anonymous Dec 13, 2007
    same
  • Anonymous Feb 19, 2008
    Same
  • Duong_Qua Mar 04, 2008
    I have the same problem but only one time. What should I do replcae the light buld.
  • Anonymous Apr 27, 2008
    same problem for 2 months. Had repair man here 4 times already
  • dfranklin7 Apr 28, 2008
    same
  • Anonymous Jun 03, 2008
    same here, Anyone has solved the problem?
Josh Crager
    Sergeant:
  • 233 Answers
FYI - I had the same problem, I removed the entire ballast board and re-soldered every connection - no troubles since, and this was a year and a half ago!
Posted on Apr 02, 2008
  • keepitsmpl1 Apr 10, 2011
    How did you get to the ballast board? Do you have to take the whole thing apart like it says in the service manual? There's not a lot of room to work inside the housing. I have the same tv doing the same thing.
Anonymous
    President:
  • 3,130 Answers
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Posted on Nov 07, 2007
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
1,435 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
