I take it the reason the bearings were changed is because of the shaking or were they making noise?
So can you feel the shake in the steering wheel or only the seat of your pants? The reason I ask is to help isolate where the shaking is coming from,, front or rear of the vehicle.
If you feel it in the steering wheel then it's in the front, seat of pants, rear.
The shake could be caused by many things. I'll assume it's the front. Possible causes;
Wheels out of balance.
Uneven torque on lug nuts.
Bent wheel.
Shifted belt in tire.
Warped brake rotors.
Rotor installed and the raised rust spot(s) on the rotor to hub interface isn't aligned with the hole(s) in the hub.
Rust on rotor braking surface.
These are the ones I have seen over the years and I'm sure there's more.
1# One or both front wheels out of balance
2# Uneven wear on front tires
3# Buckled/ out of round wheel rims
4# Lose wheel nuts
5# Lose front wheel bearings
6# Warn or lose front end components
SOUND LIKE BAD WHEEL BEARING.SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS. GRAB THE FRONT TIRE WITH BOTH HANDS ONE HAND ON TOP TIRE OTHER HAND ON BOTTOM OF TIRE. TRY SHAKING TIRE.IF SHAKES LITTLE WHEEL BEARING BAD.IF DONT SHAKE WHEEL BEARING OKAY.
will try to help. when front wheels shake while applying brakes and you can feel shake in steering wheel, front brakes and rotors need replacement.rotors are warped,if you replace front brake pads, it will return[shaking when you apply brakes] suggest that you replace front rotors[both] replace [both]front brake pads. cost? i would charge [brake pads cost $55.00] labor,$60.00] total $115.00 thank you for choosing fixya.com
