The short answer is there's a problem with the server you are attempting to connect to. If you're using a bookmark or shortcut, try typing the URL manually. It is very likely your URL is sending you directly to the bad server in a multi server environment.
Google Error 500 is one of the most widely recognized errors which is profoundly experienced by the clients at whatever point they attempt to get to a site. This error code implies that something turned out badly on the site's server. There could be numerous different purposes for this error and it doesn't mean you can't fix this issue. Make a call on Google Customer Service number 1-888-587-9269 anytime and fix all issues with the help od experts.
https://www.numberreviews.com/how-to-fix-google-error-500
http://www.numberreviews.com/how-to-fix-google-error-500
Good morning Jenna,
Majority of the time, a 500 connect fail error is associated with a HTTP Error 500 Internal server error. I am not sure if this is what you are referring to, if not, do let me know and I will address it accordingly.
So, what is an error that is presented when the Web Server (the program running the Web Site you are trying to enter) encounters to renders an unexpected problem that prevented it from fulfilling the request by the client (yourself via your web browser i.e. Google Chrome, Internet Explorer and the like).
If this is the problem you are having when you attempt to access a website, then there is nothing you can do unless you own the website and have access to the software running it.
I hope this helps,
Cheers,
MarkyyG123
