Question about Mitsubishi WS-65869 65" Rear Projection Television
5551355 green light blinking capasitors are bad need to know number on capasitors
555135555 t.v. dm board needs new capasitors,whis is the number for capasitors & where are they located?
Ed Mir
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Well, I fix it my ws-55517 and I changed 4 capasitor from DM Board, numbers :C81..C81a..C82b...C81c....1000ufd,16v,105c
Posted on Jun 22, 2014
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Posted on Nov 05, 2007
Anonymous
SOURCE: Blinking green light stays on and TV won't turn on.
Green Blinking Light - Order a DM Modual from Mitsubishi. Read the plug labels when reinstalling.
Posted on Dec 14, 2007
Anonymous
  • 80 Answers
SOURCE: blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
Posted on May 22, 2008
Anonymous
SOURCE: mitsubishi WS-55909 dm board repair
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
[email protected]
Posted on Oct 16, 2008
SD Tech
SD Tech
  • 14553 Answers
SOURCE: How do I fix The blinking light some say it the
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard2_bing.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 18, 2009
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Feb 20, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Green light flashing
this means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
Jan 02, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
Jun 03, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green led light on for 3 seconds then off, will not power up
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Dec 15, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
