Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars pool heater check or jump thermocouple how
How to check or jump
5 Related Answers
Anonymous
SOURCE: Lars Lite 2 pool heater will not ignite
The easiest way to troubleshoot any heater, is to call the manufacturer. Their techs will walk you through each possible problem and solution until you find the answer.
Posted on Oct 03, 2008
Anonymous
  • 22 Answers
SOURCE: Laars lite 2 LG or LD Pool Heater- Heater won't stay on
the control module is the problem it allows the heater to come on then turns off power to the gas valve.if you are not getting enough water flow the high limit is turning the heater off then your problem is flow.
Posted on Feb 19, 2009
Anonymous
SOURCE: laars lite 2 pool heater burner not lite
ive got the same problem and am fitting a new thermal generator i will let you know if it works
Posted on Feb 28, 2009
Anonymous
  • 92 Answers
SOURCE: Laars model# LG125n-c
could very well be thermocouple or fan switch if you have a meter that reads millivolts you can check thermocouple output or fan switch for continuity if you jump out fan switch be careful cause you can go boom if you are not familiar with this type of equipement you should call someone who is
Posted on May 11, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: How do I access the thermocouple on my Laars Lite, LLD-400N
whoo told you it does the trick?The only trick I know that works on a thermocoupler is replacing it with a good one. It is the probe that sits in the pilot flame. If you take it out to scrub it, you may as well put a new one in its place . They are relatively inexpensive.
Posted on Jun 01, 2009
Where's the thermocouple teledyne laars xe pool heater
follow the silver tube from the gas valve follow down under
I need to replace the heater gas pilot
The pilot ? or the thermocouple? or the igniter. Download your manual at:
http://www.laars.com/DOCUMENTDOWNLOADS/ProductManuals.aspx or main web address is www.laars.com
Ignitor
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Teledyne laars series 2 pool heater pilot is on,gas is on,switch is on,pump is on,water flowing to pool,replaced thermocouple, and heater wont kick on. thermostat is set. what am i missing. Is there...
First of all, I'm assuming that your heater has a pilot and not self ignition.You will need a jumper wire ( 16" of wire with an alligator clip on each end)attach one end to the terminal on the gas valve that the red wire from the pilot generator is connected to ( pilot gen. is the thing the pilot flame touches).
Now attach the other end of the jumper to the terminal where the wire from the connects to the knob where you set the water temp).
NOTE:
JUMPING BYPASSES ALL BUILT IN SAFETY DEVICES AND IS FOR TEST LEAVE THE JUMPER CONNECTED TO RUN THE HEATER FOR HEATING PURPOSES!!!!
Pool heater will not stay lit
Miles
We have a teledyne gas furnace whose pilot won't stay lit. Any ideas?
Is this a standing pilot,or pilot always on.
If so a bad thermocouple will cause pilot to go out.
Thermocouple is a small copper tube running from the pilot light area to the gas valve. easy to replace.
1helpful
Laars model# LG125n-c having problems with heater , pilot stays on but heater will not kick in. Could it be my thermolcouple? or my pressure switch? Natural gas 125,000 btu's for above ground pool
Heating & Cooling Logo
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
