Question about Nakamichi SoundSpace 2 MP3 Player
I cant format my memory card
Hello !!!
i wanna know how to format my memory card ..smartmedia 3.3 v
for the nakamichi soundspace2
Posted by ticul on
Anonymous
  • 1,234 Answers
Hello there =)
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    The camera beeps when we put the card in.
    The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
    If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
    To insert the memory card:
    1. Make sure the lens cover is closed (the power is off).
    2. Open the memory compartment on the side of the camera.
    3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
    Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
    4. Close the memory compartment cover.
    If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
    I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
    Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
    What about capacity of its memory cared? As after only 3.photos its shows the card is full. also could you pls. send me a copy of my finePix 4800z operating manual in english as what i have is in japanies.
    If 3 images fills it up, the size of the memory card is probably only 4 or 8MB.
    The camera can use Smartmedia cards up to 128MB.
    You will probaly need to buy 2nd hand cards as Smartmedia cards are no longer manufactured.
    I can send you a manual if you inform your email address.
    Feb 08, 2010 | Fuji FinePix 4800 Zoom Digital Camera
    Format 32mb smartmedia in FAT12
    Hi friend,
    ok you can try to format on windows xp.
    Follow these steps:
    1.Open Control panel
    2.Open administrative tools
    3.open computer management
    4.then click disk management
    select the drive and try to format as per you requirements . note that you can also delete the partition and create new..
    ok
    Regards
    Uttam
    Jan 13, 2010 | SanDisk 2GB microSD Memory Card
    Problem with my olympus memory card
    Hello Mr
  • Apr 04, 2009 | Olympus FE-20 Digital Camera
    Cant get anything when i installed the memory card for my olympus
    If this is a C-700 camera the only memory card that can be used in that camera is a Smartmedia card from 16mb to 128mb. An xD card is not even supported by that camera at all.
    Apr 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
    D-380 smartmedia card formatting
    There is something alled the CIS header on Smartmedia cards. If that is missing or damaged, any compliant Smartmedia device will not let you use the card. Many card readers are not Compliant and thus ignore the CIS block.
    It is advisable to not try and "recycle" cards with a damaged CIS block by using them in a non complying card reader because of one of the reasons why the CIS block is there is to ensure something called the bad block table is present on the card as well. The bad block table maps the locations of bad memory cells and prevents writing to them so the card will apear 100% good. All cards have some bad cells from the factory even. Most likely the bad block table will be missing as well and your non complant card reader will end up writing over bad memory cells which will cause future read errors and data loss.
    You would need access to a compliant Smartmdia reader that is compatible with the SMPREP (or similar) formatting utility to fix problem smartmedia cards. SMPREP fixes the CIS block and scans the entire card for bad memory cells and updates the bad block table.
    Mar 13, 2008 | Olympus Camedia D-380 Digital Camera
    Card problems
    In this case I would try to use SMPREP Smartmedia formatting utility on the problem card. Basically I was able to get an older ZIO! Smartmedia reader that supports SMPREP off Ebay for $7 total for a similar situation where I had a couple of useless problem cards that I had laying around for a couple of years. IMHO Smartmedia is a little more prone to getting problematic because the card is simply a raw flash memory chip, with no sort of dedicated controller to watch over it. All Flash based memory cards have bad block management that finds and corrects most bad areas on the card automatically that is transparent to the user. With smartmedia, since there is no dedicated controller, the card's bad block table can get out of date. The SMPREP utility scans the card and rebuilds the bad block table so the card will be like new again.
    Feb 12, 2008 | Olympus Camedia D-510 Zoom Digital Camera
    For formating card
    Try http://lclane2.atspace.com/olformat.html
    The Olympus C-830L camera is the same as the D-340R
    Jan 15, 2008 | Olympus Camedia C-830L Digital Camera
    Olympus camedia C-830L.
    Hello
    Problem formating smartmedia memory card olympus c-830 l . Model card M-8P D3V20 , 8 Mb.
    No user manual c-830 L , no guide for formating .
    My format card for pc - fat 32 and desastre .
    Please , information for formating card .
    Sorry , no speek english .
    My adress :
    Nicolae Grozav
    Loc. Arbore nr. 769
    Jud. Suceava - region Suceava
    Cod - zip 727015
    ROMANIA
    Tel. +40 0230/539336 or +40 0742/551259 - mobile
    email : [email protected]
    Yours sincerely , Nicolae Grozav
    Jan 19, 2007 | Olympus Camedia C-830L Digital Camera
    Ruined Memory Card??
    No one can expend efforts to diagnose, repair or let alone talk to you about what may be a 25 to 30 dollar memory card. I've had dozens of such failures but I deal with a fleet of devices and these are spread over the world now. The card, if the camera will not format it is tossed and you get a new one. Whatever you plugged it into is marked as suspect and I'd not do that again.
    Sep 06, 2005 | Olympus Camedia Stylus 300 Digital Camera
    Nakamichi SoundSpace 2 MP3 Player Logo
    54 people viewed this question
    Top Nakamichi Audio Players & Recorders Experts
    da surgen
    Ekse
    Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
