Question about Doro Phone Easy
Why can some images become wallpaper and others cannot when they are all jpg
Cannot set as desktop
If you are unable to change or display the wallpaper of your Windows 7 or Vista desktop, try this :
(1) Open Control Panel > Ease of Access Center > Make the computer easier to see.
viswalp.jpgEnsure that Remove background images (where available) is unchecked.
Save, Apply, Exit.
This should help !
(2) If it doesnt, try this:
Run regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies
Then right click on Policies > New > KEY > name it as "ActiveDesktop".
Next in RHS, rt click > New > DWORD > name it as "NoChangingWallPaper" .
The DWORD value 1 will restrict change in desktop wallpaper. To allow change give it value as 0.
Reboot.
(3) If it still doesnt work, maybe your TranscodedWallpaper.jpg file has become corrupted.
Open explorer and type the following in the adress bar and hit Enter:
%USERPROFILE%\AppData\Roaming\Microsoft\Windows\Themes\
Here, rename TranscodedWallpaper.jpg to TranscodedWallpaper.old.
Next, double-click slideshow.ini file to open it with Notepad. Empty its contents. That is, select all the text and delete it. Save the changes. Close explorer windows.
Hope something helps!
Dec 03, 2012 | Acer Computers & Internet
Tip
How to change your computers background into something cooler
<li> <p>Click on the Start menu button. Then click on Settings and then on Control Panel.<br /></li> <li> 2 <p>Double-click on the Display icon or text link. This will open a window named Display Properties.<br /></li> <li> 3 <p>Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.<br /></li> <li> 4 <p>Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.<br /></li> <li> 5 <p>Click on Browse to use an image stored elsewhere on your <a href="http://www.ehow.com/how_5177_change-background-picture.html#">hard drive</a>. Locate the image and click Open.<br /></li> <li> 6 <p>Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.<br /></li><br /> <span>Tips & Warnings</span> <ul> <li> For background pictures, you can use scanned or digital photographs, an image downloaded from <a href="http://www.ehow.com/internet/">the Internet</a>, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.</li> <li> Wallpaper consisting of large image files will consume memory and system resources. Consider using a small image and tiling it if resources are scarce.</li></ul><br />
on Jan 04, 2011 | Computers & Internet
Tip
How to have background wallpaper into your hard drive or folder?
Hi guyz,
for this u have to create a note pad file.
1. Open note pad
2. copy and paste following statements:
[.ShellClassInfo]
IconFile=%SystemRoot%system32SHELL32.dll
IconIndex=116
ConfirmFileOp=0
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
{8BEBB290-52D0-11d0-B7F4-00C04FD706EC}={8BEBB290-52D0-11d0-B7F4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
IconArea_Image-=
[{8BEBB290-52D0-11d0-B7F4-00C04FD706EC}]
MenuName=T&humbnails
ToolTipText=T&humbnails
HelpText=Displays items using thumbnail view.
Attributes=0x60000000
3. Save that file as destop.ini
4. Now save it into any drive
Eg. c:
create folder naming "folder settings" and paste some images
suppose u save
now open desktop.ini file
now edit the line
IconArea_Image-=
nw save and enjoy.
Regards
Mohit Baluni
[email protected]
on Oct 11, 2010 | Computers & Internet
How to add wallpaper to flash drive background?
First you need to create a desktop.ini file in your flash drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a ".jpg" file
Open desktop.ini file from your flash drive. Copy and paste below code to it.
Last line of the code, you can see "IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper name.
Attributes=1
Save your file. Unplugged the flash drive from PC and plug it again. That's it.
If you need more information
Visit SmartUSB.net
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Jul 25, 2012 | Electronics - Others
How to change the picture on my desktop?
If you're trying to set a picture that's online to your desktop (called wallpaper) you can just right click on it and click "Set as wallpaper" or "Set as desktop background" or something similar.
Conversely, you can right click anywhere on your desktop and go to Properties (in windows XP) or Personalization (windows 7 and Vista) and change it from that dialog box.
Jul 27, 2011 | Samsung N150 Netbook
Tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 | Computers & Internet
I cannot change my wallpaper!!!
Instructions
Step 1
Step 2
Step 3
Step 4
Step 5
Click on Browse to use an image stored elsewhere on your hard drive. Locate the image and click Open.
Step 6
Tips & Warnings
For background pictures, you can use scanned or digital photographs, an image downloaded from the Internet, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.
Please give the positive feedback. Thanks for using Fixya.
Anand Kumar
Apr 12, 2010 | Acer Aspire One PC Notebook
Nokia n97 wallpaper image
Have you upgraded your firmware to 11.0.021. if not then upgrade it.and try putting some other wallpaper if it still ives problem then restore the phone to default seetings
Aug 06, 2009 | Nokia N97 Cell Phone
Changing wallpaper on samsung f 480 main screen
YES YOU CAN CHANGE THE MAIN SCREENS WALLPAPER. sIMPLY TRANSFER ANY BMP OR JPG FILE INTO YOUR IMAGES, THEN SIMPLY SELECT MENU, MY FILES, IMAGES, TOUCH THE IMAGE YOU WANT TO USE, SELECT OPTIONS, SET AS, WALLPAPER. OR GO INTO THE SETTINGS CHOOSE 'DISPLAY AND LIGHT SETTINGS', 'DISPLAY SETTINGS', 'WALLPAPER', 'IMAGES', THEN JUST SELECT THE IMAGE YOU WANT AS YOUR WALLPAPER.
HOPE THIS HELPS
Oct 18, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
I've been trying to download a full screen desktop (wallpaper ... I don't know the difference) for months. All I get is a small picture so I therefore, have about 5 small pictures of Barack and I want a...
Here are a couple of wallpapers I found, simply click on the link....when the image loads, right click it and select "Set as desktop background".....that should do it for you!
1: http://magdelene.files.wordpress.com/2008/02/barack-obama-08-desktop-wallpaper.jpg
2: http://nostromus.files.wordpress.com/2008/03/obama-wallpaper_change.jpg
3: http://obamamedia.files.wordpress.com/2008/03/change-we-can-believe-in-1024px.png
Also , if you want to use one of the wallpapers you downloaded before (the small ones) you can stretch them to be full screen by following these instructions:
  1. Hit the "Start" button
  2. Goto "Control Panel"
  3. Double click the icon that says "Display"
  4. Click the top tab that says "Desktop"
  5. In the middle on the right is a drop down box that says "Position" , select the "Stretch" option.
  6. Hit OK
Sep 29, 2008 | Computers & Internet
Doro Phone Easy Logo
18 people viewed this question
Top Doro Lands Phones Experts
Marvin
Marvin
Vernon Taylor
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
