My Badger 5 garbage disposal is leaking from a seam at a point where there is a screw.Very slow drip when water is runnning. How can I fix it? Or,can it be fixed?
SOURCE: garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
SOURCE: I have a badger 5 plus garbage disposal (5-6 years) it humms
Yes, it sounds like you have a bad motor winding, not allowing the motor to actually work. It is time to replace. Hope this helps
SOURCE: Garbage disposle makes a humming noise when turned
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
Yes. it is not hard either...
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
heatman101
c
heatman101
g
heatman101
heatman101
p
