Question about Brother MFC-5440CN All-In-One InkJet Printer
How can i change absorber pads on MFC-685CW - Brother MFC-5440CN All-In-One InkJet Printer
3 Related Answers
Anonymous
  • 164 Answers
SOURCE: keeps asking for bril07a.dll off of the Brother
Go to Brothers web site and download the drivers for the device, reinstalling should replace that driver. You mighht also try doing a search on your system and see if the file exists, but maybe not where the software is looking for it..if so, copy it to the location that whatever it is that keeps asking for it, is looking
Don't forget to rate the advice!
http://www.aa1consulting.com
Posted on Jul 31, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: unable to change 4f
Hi there
Brother 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
Anonymous
  • 567 Answers
SOURCE: How do I change the
Open the printer as though you were going to install new ink cartridges then unplug the printer.
Locate the waste ink absorbers in their black rubber frame. They will be located underneath the area where the ink cartridges rest when the printer is in standby mode.
Use a paper napkin to soak up any excess ink that may be in the pads.
Pull the rubber frame free from the printer, wearing gloves to keep your hands clean. Carefully remove the ink absorber pad or pads from the rubber frame. Now insert new ink absorber pads firmly into the rubber frame. Replace the rubber frame in its original position and close the printer.
Hold down the power button, then plug the printer back in. Continue holding the power button down until the printer begins to reset itself and come online.
Wait for the green power light to turn off, then press and release the power button again. It should blink for two to three seconds, then stay lit; this will indicate that the printer has been reset and is ready to print again without errors.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating.
Posted on Sep 30, 2010
I have the Brother MFC-685CW Fax Printer, I replaced the Yellow ink cartridge but it still comes up with message "Yellow No Ink" What can I do?
Hi there
You can try.
Just take them out and gave the brass connexions a good clean and put back.
All the best Pineworks
I can not scan from my brother MFC-685CW to my computer, how do I fix it please ? thank you
dear first un-install the driver, & restart the pc. then install driver again then restart. so after check it for your scan
How can i instalation for MFC-685CW
I found this on the Brother Web Site. You can download the drivers here. If you find this helpful, pls rate me.
http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-685CW
Good Luck
I need a cd for my mfc-685cw brother prenter pl
You can download your mfc-685cw brother printer drivers, utilities, and firmware or you can download it all in this link: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc685cw_us_as
12helpful
2answers
How do you reset a Brother MFC-7840W printer to factory default settings?
Menu * 2864 (within 2 sec.), 0,1, when 'maintenance' appears, press 0,9 to exit.
Brother mfc-685cw ran out of black ink
I had this problem and after shaking the cartridges (all of them) and putting them back, turning the machine on and off I noticed the printer wire was under one of the feet of the machine. One of these things worked and I believe it was the cable under the machine confusing the machine..............not very technical I know but just in case,,,,,,,,,,,fingers crossed
1helpful
Need instructions for brother mfc-685cw in cartridge refilling
This is what you need it has the 4 user manuals for MFC-685cw
http://www.brother-usa.com/manuals/default.aspx?ProductID=MFC685cw&ProductGroupID=5
If your trying to use an ink refill kit... just poke tiny hold in top and fill with syringe
Brother MFC-5440CN All-In-One InkJet Printer Logo
Ekse
k24674
