Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Why HP officejet pro L7580 keep going off line
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: Ink fading and streaking
Do you use original HP cartridges?
Posted on Jan 31, 2008
wayneard
Wayne Mineard
  • 1901 Answers
SOURCE: Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Posted on Jan 09, 2009
Anonymous
  • 129 Answers
SOURCE: "Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Posted on Feb 28, 2009
Anonymous
  • 113 Answers
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
levi biteng
  • 298 Answers
SOURCE: my HP officejet Pro L7580 says the printhead has a problem
Re-insert the print cartridges. It is also possible that the heads are burnt. Get a new set of print heads (black/yellow) and install to the printer. If problem persists, clean the contacts on the printers. Use acetone + cotton swabs.
Posted on Mar 16, 2009
Where do you find a driver for the Officejet Pro L7580 for an Mac
Good Day Nicholas!
You can find the HP Officejet PRO L7580 driver for MAC from the download link below
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=2512008#N199
Please don't forget to rate my answer.
Jul 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I have a HP Officejet Pro L7580 ain. I did not used it for almost 2 years. Now I tried to used it again but sometimes I only get magenta or gray pages, not even black, and a parcial page with a lot of...
Hello
To keep the printer such a time time, dried ink cartridges, if it has ink, then put the cartridges into warm water and put them back after dry. otherwise you need to replace cartridges.
Refill is also an option.
Good Luck
Jan 17, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
How can i add an HP printer officejet pro L7580
All the software/drivers for your HP printer can be installed by clicking on the link below:
Just select the OS you use, and you are good to go for the free download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=2512008&#
Mar 15, 2010 | HP OfficeJet Pro L7580 InkJet Printer
I had HP Officejet Pro L7580 set to ask me which
Looks like you have saved the method as 'default'. If you open HP Solution Center and go to "Settings" and then choose "Scan settings" you can figure out the details from there. At some point, you choose not to save this as default and ask it to prompt each time..
Jan 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My officejet pro L7580 printer is printing horizontal black lines on my pictures. What can I do for this?
you more and likely would need new printheads, this particular printer is one of the worst HP ever produced. i have these in the shop weekly.
Nov 11, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Please provide driver for HP Officejet pro L7580 operating system window vista
http://www.userdrivers.com/Printer/HP-Officejet-Pro-L7580-Color-All-in-One-Basic-Driver-for-Windows/
please rate
Jun 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Bought used HP Officejet Pro L7580, cant find hole for plug in to
It is a small round hole. You need an AC Adapter.
Check eBay or www.hp.com partsurfer
Feb 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
44 people viewed this question
Ekse
efs_perpends
efs_perpends
