Question about HP Deskjet 3510 e-All-in-One Printer
Why do I have lines missing?
What is causing my emails to be printed with random lines missing when printed in Portrait, but print without problems when printed in Landscape. I had the same problem when printing from a second printer as well.
5 Related Answers
Everett Lin
  • 990 Answers
SOURCE: printing in landscape
Hello sir; the problem is on computor side when click print you better click print preview then go to set up what you want.
Posted on Jan 08, 2009
Anonymous
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Posted on Jan 20, 2009
Anonymous
SOURCE: HP C7180 printer prints 1 p. LANDSCAPE, next p. PORTRAIT, etc.
I had the same problem. I uninstalled the printer on the offending computer, rebooted, reinstalled and it ironed itself out.
Posted on Mar 20, 2009
Anonymous
  • 40 Answers
SOURCE: My 5510 all in one is all of sudden printing in
re-install printer driver and install again.
Posted on Aug 08, 2009
brett207
brett207
  • 231 Answers
SOURCE: the printer keeps printing in landscape form even
This sounds like a software problem...
Try using the PCL5e driver instead.
Posted on Jan 27, 2010
Tally genicon 6605 is printing from top to bottom of the page...what could be the problem
I think it depends on what you mean by printing from top to bottom of the page.
If you are describing the print being rotated by 90 degrees so rather than a line of print going across the page from left to right, the print goes up and down the length of the page.
The most common cause of this is that you are printing from a Windows application and you have set the page orientation to LANDSCAPE rather than PORTRAIT.
With in the application you are printing from look for the PAGE SETUP options ensue you select PORTRAIT.
This should rotate the print.
Oct 18, 2013 | TallyGenicom Office Equipment & Supplies
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
When printing email most of the text is missing
This usually ocurrs because your printer margins are incorrect.
At your email program or at your word program Do a preview first and set the margins
Use the option (fit the doc to a one page)
Check how many pages are demanding your document, and delete the unnecesary pages
Check your printer setting in your email program or in your word document
Check if your printer is using "landscape" instead of "portrait"
And try printing again.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Ricoh CL7000 - Black lines every 4,5 or 9 pages
Sounds like the registration clutch is faulty. The knocking maybe the fuser unit jumping gears check that unit also check that the green paper holders are all in the correct place.
Thanks Jason
Jun 30, 2008 | Ricoh Aficio CL7000 Laser Printer
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
