Question about Dell HK395 Computer Speakers
HK 395 howto make the subwoofer work
2 Related Answers
Anonymous
  • 4 Answers
SOURCE: HK 395 teansformer
CVB
Posted on Sep 15, 2008
Petrica Voicu
  • 64 Answers
SOURCE: where can i buy the cable to connect the
Posted on Aug 07, 2012
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Where to buy the replacement cable for HK-395 Sukwoofer
Hi...
You can buy a replacement of your cable in the internet. Visit this site and buy it online.
www.ebay.com
The online selling website.
Regards
PCmania
24helpful
2answers
Del harmon kardon hk395 9 pin plug
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Need user manual for JVC KD G 395
free manuals are available on elitezoom.com they should have 1
1helpful
Need Manual For Durabrand HT395
Durabrand HT-395 User Guide
If that link doesn't work, you can still find the manual with the following link:
www.retrevo.com
Just put HT-395 into the search box in the upper right corner and the page to download the manual should appear.
Dell HK 395 Speaker System - Need Circuit Diagram Download
1.  Check the orange multi-pin connector the sufwoofer for a broken or bent pin.  If there is a broken pin you can bypass it by cutting open the cable jacket and tap onto the affected wire with a 6 inch or so jumper, and then attach a jumper to the appropriate point inside the subwoofer.  Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
2.  Try wiggling and rapidly rotating the volume control.   There are reports this control may become a problem as it ages.
3. I haven't been able to find a schematic.  My only recourse was to google the output amp and the 2 op-amp packages for data sheets.  They are readily on the internet.  Then I laboriously traced out the stereo paths.  I found that red and black fine tip felt pens were helpful in marking out the signal paths through the circuit boards.
Dell HK395 Computer Speakers Logo
Top Dell Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
