Xerox Phaser  6110 Laser Printer Logo
Anonymous Posted on Jun 21, 2014
How do i adjust heat settings in xerox 6110
Im trying to print transfer paper bet it keeps smudging and causing a paper jam help please.i have been looking for solutions but can not seem to find any.
Harrie
Level 3:
Top Expert:
  • Xerox Master 6,746 Answers
  • Posted on Jun 22, 2014
 Harrie
Xerox Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285705
Points
83153
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
1helpful
Smudged ink
Chances are the fuser is not working correctly. How warm is the paper as soon as it leaves the printer? It should be quite warm. The fuser heats the toner and 'fuses' it to the paper. If the fuser does not get hot enough, then the toner which is a powder smudges on the paper. Also not setting the correct paper type for a tray will also cause the toner to smudge as the printer adjusts the temperature based on the type of paper selected.
1helpful
I get a paper jam every time I use my Xerox 6110 MFP Printer. It jams on every document while printing or copying.
same problem here expert at Xerox adviced to clean black rollers on the papertray
maybe it works for you, not for me though ;-(
1helpful
Xerox 6110 bad print at paper over 80g
you need to read the machines stats.the dos and donts of the machine
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
2helpful
Blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
2answers
Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
2answers
Xerox 8825
hi im jules_09.have you tried changing you cleaning blade or roller?if yes check the exposure lamp my its deffective if not.also black copy is cause by over tone developer is also deffective
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
