SOURCE: Emerson NR303TT CD Shelf System
Tienes que llevarlo a un centro de reparaciones ya qur por lo que dices los ICs amplificadores de audio estan danados.
SOURCE: Resistor burned on my Grandmother's
Hello Gio, Hi, a burned resistor is usually caused by a shorted part like a semiconductor or regulator, there are two things you should do, find the value of the resistor and what caused the resistor to burned, for the Resistor, the value is usually written on the board, If not you can find the value on schematics diagram (which is usually hard to find, but if you have one, fine), and on the same working model (very remote a possibility). IF this are not available, you now need the assistance of a technician.
SOURCE: NEED A DRIVE BELT FOR MY EMERSON NR303TT
www.partstore.com >emerson they will have the drive belt u are looking for
SOURCE: Emerson Heritage Model # NR303TT
Sounds like a dirty volume control switch!
If you could open the radio and look for the volume control inside, spray some contact cleaner if there is small hole on the metal cover of that volume control, after spraying play(side to side movement) the knob of the switch so that the contact cleaner would spread inside the switch.
If that does not help, you should replace the volume controller switch with the same value.
A simple electronic technician could replace it.
Hope that helps you out!
Thanks for asking FixYa!
