Car Audio & Video Logo
Mike Hamer Posted on Jun 21, 2014
How do i wire a 12 hifonics subwoofer and a planet audio 2 channel amp to my f 150 sync
3 Related Answers
Anonymous
  • 109 Answers
  • Posted on Jul 17, 2008
SOURCE: i want to install a
Get an aftermarket to factory wiring adapter. You can find out exactly what part you need by following this link:
http://www.crutchfield.com/cgi-bin/autoinfo/autoinfo.asp?lp=%2fapp%2fCar%2fMyCar.aspx
Anonymous
  • 155 Answers
  • Posted on May 11, 2010
SOURCE: I have a P12DVC 12
i had found out you can down load all most any maunal for car audio from retrevo.com and type in your model number hope this was helpful
jturcotte
Jeffrey Turcotte
  • 8991 Answers
  • Posted on Mar 22, 2011
SOURCE: Hello..im trying to find a
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
OK let's try this I have cerwin vega mobile audio speakers 2 pairs vega369x 6x9 @ 75 rms 4ohm and 1 sub 200 rms @4 Ohm want to wire them to a planet audio 1600watt 2Ohm 4ch amp
Your can go down to 2 ohm but will take 4 fine wire your 6 x 9 s to one side one ch each and bridge the sub across the other 2 channels.
Wats the best way to hook up 3 hifonic hfx12d 12s. Dvc 4ohmd to a 2 channel 2600 watt planet audio. Amp is 2 ohm stable.
Wire each sub 8 ohms(sieries) than connect them in parallel, bridged @ amp, final impedence will be 2.6 ohms.
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
How do i wire a solar baric l5 to a planet audio 999w amp?
You should bridge your speaker on the amplifier. Check your connections on your amp. Normally it will be the - (Minus) on the left channel and the + (positive) on the right channel
2answers
I am wondering about car amplifiers, I don't know what kind to get, I have Alpine 6.5" 2-Way Car Speakers (SPS-600), 80 watt as my front speakers, and Alpine 6 1/2" 2-Way Car Speakers (SPR-17C), 100 watt...
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
2helpful
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
I have a Hifonics BXI1208d mono subwoofer amp but i have 2 sets of wire terminals and they go negative negative postive postive. Which do I use?
Depends if its bridgeagle or bridge internally. bridgeing provides the most power to a mono system. 2 positives and 2 negative you have a 2 channel amp. Heres a link to check out, you should be able to figure out your system and hook it up with this. Hope it helps. http://www.wikihow.com/Bridge-an-Amplifier
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Andrew
ADMIN Andrew
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
