Same here, all of a sudden with in a month both my key remotes stopped working, replaced batteries, nothing. grrr
I had the same problem. Is it a "Karr" remote? If so, I think they use really cheap switches. What I did to fix this is opened it up, de-soldered the switch from the trunk release circuit, de-soldered the broken switch from arm/disarm circuit, and replaced it with the working switch. Works perfectly. If you don't own a soldering iron, I suggest you buy a new one or buy a better alarm system.
That happened to mine too. Is it a "Karr" remote? If so, it seems as if they use really cheap switches. I ended up de-soldering a working switch from the trunk release circuit and soldering it onto the alarm arm/disarm circuit. Works perfectly now. If you don't own a soldering iron, I recommend getting a new one or getting a better alarm system.
