Question about Simplex Kaba E-Plex 3000 Narrow Stile electronic keyless lock
How to reset Kaba atlas M-unit - Simplex Kaba E-Plex 3000 Narrow Stile electronic keyless lock
Grady Turner
    Scholar:
    New Friend:
  • 101 Answers
Compressor motor converter failure for compressor GA315VSD
if it is this unit this link may help you
http://www.about-air-compressors.com/atlas-copco-compressors.html
or try this one you tube link
https://www.youtube.com/watch?v=QUj-mrzxS4o&ab_channel=ChouseMolla-Storm
How to reset Atlas Copco Electric Air Compressor
Sep 17, 2017 | Air Tools & Compressors
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Dec 25, 2015 | Locks & Locksmithing
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Cannot get it to accept the user pin numbers. Have entered the master code and also reset the manual reset to default.following the manual and using the # sign before and after master code. red light comes...
Recommend that you contact Kaba Ilco with your problem.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Jul 01, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
Code was forgotten and need to reset somehow. is there any way to do it by myself?
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the right-most column on the manual grid page, labelled "TIPS", and there you will find the files with the programming instructions.
As you will see, there is a reference in those instructions for the need for a DF-59 key. A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Also, there is a need for a spanner wrench. The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Kaba-Ilco Customer service can be contacted from this link:
Jun 20, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Door lock push button not working, reset lock at top of lock box works for a day and then buttons won't work.
I can't answer your question directly, but i can steer you toward some contact and technical information:
Feb 18, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Had to replace a return spring under the clutch and now the clutch arms won't reset the combo pack if a wrong code is entered.It does work if the right code is entered
I recommend that you contact Kaba Ilco directly with your problem.
Jan 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lost code
Kaba Ilco has a FAQ document on resetting the code here. If you need more detailed information, your user manual is here.
I'd highly recommend looking at the FAQ. Basically you're going to have to open the unit up, reset the gears so all the slots are lined up facing you, then put the unit back together.
Once you've got everything back together, you turn the outside lever to the stop position, release it, and enter the new combination. Turn the outside lever tot he stop position again, and you're done.
Jun 15, 2010 | Simplex Kaba Ilco Unican LP1000...
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
Simplex Kaba E-Plex 3000 Narrow Stile electronic keyless lock Logo
546 people viewed this question
Top Simplex Locks & Locksmithing Experts
JonSnell Electronic
JonSnell Electronic
Chris Walker
Chris Walker
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
