Question about Philips Magnavox 27MS343S 27" TV
Magnavox tv 32MF338B/27 WON'T TURN ON - Philips Magnavox 27MS343S 27" TV
4 Related Answers
69camaro
SOURCE: Magnavox 27
THANKS FOR THE INFORMATION ThaMp3DOCTOR. PRESSING THE VOLUME+and CHANNEL+ SIMULTANEOUSLY FOR 5 SECONDS WORKED!   THANKS
Posted on Jun 10, 2008
Anonymous
SOURCE: 27'' TV will not turn off demo mode
My ancient TV/VCR Quasar combo had the same problem...and I don't have the original remote control. But holding down the "play" button for five seconds did the trick. Perhaps your TV is similar. I also read that holding down the "menu" button works as well. Hope this helps.
Posted on Apr 23, 2009
SOURCE: I currently have Uverse through AT&T and when
Try unplugging the modem for 20 seconds
Posted on Aug 23, 2009
gopakumarg43
  • 76455 Answers
SOURCE: how do i get regular
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Posted on Nov 04, 2010
I have a magnavox 32mf338 tv,the red light is on,when u hit the power button the green light flashes but will not turn on what would cause this
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 15, 2016 | Magnavox 32MF338B 32 in. LCD HDTV
Tv won't turn on power indicator light not lit
As you mentioned the tv have problem with the power supply stage. Before suspecting for any intenal fault Chcek the following first. Remove the AC plug of the tv and connect the same in any other wall outlet. If then also it shows the same problem then its the powersupply board of your tv.
working on power supply board should be done by a skilled worker. Because there is risk of electric shock even if the power is disconnected. some of the capacitors will hold charge even if the power is not connected.
Here i have adde the link which will lead you the powesupply board.
Power supply board
Ajin
Apr 01, 2012 | Magnavox 32MF338B 32 in. LCD HDTV
I have a Magnavox 32 inch flat screen, model # 32mf338b/f7. We used some generic universal remote, now it is stuck on 4:3 screen ratio. I cannot figure out how to get it back to the normal 16:9 ratio. ...
32MF338B F7 Magnavox
Go to above link and download the user's manual. Follow instructions to change to 16:9 setting.
You can also press the format button on your remote to change to 16:9 format.
Semper Fi,
Z
Jan 29, 2018 | Televison & Video
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 27
Mar 15, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
261 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
