DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
