Question about IBM ThinkPad T40 2373 Notebook
How to enable wifi switch asus A40J - IBM ThinkPad T40 2373 Notebook
I WANT TO GET OUT OF SAFE MODE
Theres a reason your computer is booting in safe mode do a full virus scan make sure there isnt any bugs or malware if that doesnt fix it go to start/all programs/accessories/command prompt and type chkdsk hit enter it may take time but let it run its course
My asus transformer pad will not connect to wifi. I have done the factory reset and it will not even list a wifi list to connect to.
Obviously your WiFi is not enable. Check your settings and make sure your enable your WiFi. Then you will be able to see all computers (WiFi) around you.
2answers
On asus kf2f laptop, how do i turn on wifi?
Press the fn + f2 key at the same time to toggle WiFi on and off. You can also check in Control Panel -> Network Connections to see if the adapter is disabled. If it is, right click it and click enable.
2answers
Please help me . How do you connect ASUS X58L to wireless so i can use away from home without my router. ?
Hi
Have you enabled your wifi switch or key
and does it show you down in the right hand side of your screen that wireless
networks are available
if it is not enabled then try to press the FN+F2 or FN+F8 or FN+F11 or sometimes
there is a push or slide switch to activate the wifi
My wireless is tuned on but can not fround any wireless in rangs
As if the wireless of ASUS notebook computer has two switch.You enable it in windows device manager.It is the one switch of them.But maybe it doesn't work.The other switch is on you computer's pad,near the keyboard.If you didn't find it,I suggest that you use Intel wireless control program to control you WiFi.
1helpful
2answers
ASUS wifi switch
Make sure that wifi is enabled in wireless switch utility. You can find that in the system tray next to the clock.
I cannot establish a working WiFi on my ASUS A639 PDA
You can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). You should first connect to a network from this list (possibly with a wifi password), then it should connect automaticly evertime you swtich on wifi. After you have successfully connected to a wifi, you should see the wifi icon changes in the task bar. Hope this helps.
ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
2answers
Wifi Problems with Asus A2500H notebook
That sounds very much like a software problem because it detects WIFI.
Solution:
uninstall driver through properties --> then install again
Let me know if that works for ya. Thanks.
IBM ThinkPad T40 2373 Notebook Logo
Top IBM Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
