Question about Amana SXD524VW Side by Side Refrigerator
Amana water dispenser switch not working - Amana SXD524VW Side by Side Refrigerator
5 Related Answers
Anonymous
  • 878 Answers
SOURCE: No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Posted on Nov 12, 2006
Anonymous
  • 448 Answers
SOURCE: Amana refrigerator water dispenser not working
No you don't. You have two water solenoids in the back. One for ice, one for water. Pull line off water solenoid and blow into it. For more help go live chat.
Posted on Jan 10, 2009
Anonymous
  • 360 Answers
SOURCE: Water dispenser not working
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
MDK
  • 45 Answers
SOURCE: Water dispenser for Amana Side By Side
when pressing in on the water dispenser you should hear a clicking sound from a micro switch being activated. if you hear the micro switch clicking ok then you'll have to disconnect the water at various points and retry to see which locations the where water is coming out and where it is not. Trial and error approach to narrow down the problem location. usually either a bad water valve or a freeze up in the water line somewhere. assuming water is working to icemaker.
Posted on Jan 08, 2010
Anonymous
SOURCE: My side by side Amana water dispenser no longer
you have a kink in your tubing test by checking at pump which is visable by taking back felt cover at bottom where water tube goes in cut a few inches away from pump to see if water flows when you activate swich if so you have a kink in your system to repair the cut they have couplings in the store
Posted on Mar 22, 2010
How does the easy fill water dispenser work?
there is a micro switch behind the door lever wich activates a water valve solenoid that allows water to go thru.
Oct 23, 2013 | Amana 21.9 cu. ft. Bottom Freezer...
I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Oct 02, 2012 | Amana Refrigerators
I have an Amana refrigerator model#SRD22S5W. Neither the ice maker nor water dispenser get water. I have confirmed that water is getting to the fridge but it seems the switches are not working opening to...
There is a solenoid in the back where the water line tie in. If the solenoid is bad, no water will get to either. As someone is trying to dispense water, hold a metal object (like a screwdriver) to the top of the round part of the solenoid. If there is some magnetic resistance, then the solenoid is good. If not, replace it.
May 08, 2011 | Amana 25.8 cu. ft. Side-by-Side...
MY REFRIGERATOR WATER DISPENSER IS NOT WORKING ONLY THE ICEMAKER IS?
You could have an issue with one of the following:
* water valve assembly's water dispenser solenoid (located in the lower rear of the refrigerator). If this is the problem, you must replace the entire water valve assembly.
* water dispenser actuator switch/button
Contact an appliance service company.
Feb 16, 2010 | Amana AFD2535DES French Door Refrigerator
Water dispenser for Amana Side By Side regridgerator not working. Water is flowing into the unit b/c ice dispenser is working. What are main potential issues to look at on the water dispenser?
Jan 08, 2010 | Amana 22.6 cu. ft. Side-By-Side...
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
AR2664 dispenser lights
remove the cover you will find a duel mirco switch one side is for the water the other is for the light. switch is bad on light side.
Nov 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
