Question about Tag Heuer 2000 Aquaracer Chronograph CAF1111 Watch
How do I turn off alarm on a tag heuer formula 1cac111d ?
5 Related Answers
Brian032472
Brian032472
  • 150 Answers
SOURCE: Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Posted on Nov 06, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
  • 3 Answers
SOURCE: Tag Heuer Formula 1 Mens watch
battery number 395!
Posted on Jan 02, 2009
Anonymous
  • 10 Answers
SOURCE: how can i make the date of my tag heuer formula 1
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Posted on Oct 10, 2009
Anonymous
SOURCE: formula 1 battery replacement
I did it myself.Very easy use battery #394 buy at Walmart $5 made in Germany. I bought special tool to open and close the
watch on ebay
Posted on Nov 21, 2009
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Were is the serial number on a tag heuer 1990's formula 1 chronograph model 571.513T
    It is located on the right side of the Tag Heuer logo on the back of the watch. It is not as deeply engraved as the rest of the markings on the back, but rather is very lightly 'tapped' into the metal. 71e414e4-eb33-401b-8e97-f7f3c2c92292.jpg
    Jan 17, 2013 | Watches
    How to setup the alarm to my tag formula1
    I couldn't locate your model but if you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1113.BA0850 , you will find the details of a similar watche. In the menu at the side you will see "instruction manual".
    Jun 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
    Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
    Some watches need to have the crown unscrewed.
    Try turning it anticlockwise then pull out.
    If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
    Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Tag Heuer Formula 1 with alarm WAH111A.RWV3350
    You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "formula 1"
    then "man" and then the model of your watch.
    On the right of the page is a small menu,select "user manual"
    Feb 09, 2010 | Watches
    My alarm does not sound on my Tag Heuer Kirium F1?
    Have you a copy of the manual?
    If you have, then you will see that it can be turned off (last page), is this likely to be the case?
    If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
    This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
    If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
    If not look at a similar watch for a generic manual.
    Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
    I need a user manual for the Tag kirum Formula 1 watch
    Go to the Tagheuer web site (www.tagheuer.com/)
    Select "watches"
    Select "Tag Heuer Formula 1"
    Select "men"
    Select "Tag heuer F1 chronometer"
    On the right hand side of the screen you will a menu and the user manual is the last iten on the list.
    Jan 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
    Tag Heuer Formula 1. I have set it and in 15 min
    you can find a shop to repair<a href="http://warhammeronline.cheap-wow-accounts.com/" >cheap warhammer gold</a>
    Dec 25, 2009 | Tag Heuer Formula One
    What are the two digital displays on the top of the Tag Kirum F! for??
    Use this link and read the info:
    http://www.google.com/imgres?imgurl=http://image.vialuxe.com/Newsimages/1965_LRG.jpg&imgrefurl=http://www.vialuxe.com/News/Tag-Heuer-Tag-Tag-Heuer-Watches-TAG-Heuer-Kirium-Formula-1-Watch/315,870&h=260&w=315&sz=20&tbnid=mdhtEFEWdkvSlM:&tbnh=97&tbnw=117&prev=/images%3Fq%3Dtag%2Bheuer%2Bkirium%2BF1&usg=__PEFomHqQ5EXL6ulbCMX7La4FbWQ=&ei=pMuBSsytA4KsjAfZ3LmECg&sa=X&oi=image_result&resnum=7&ct=image
    All that is one link.
    Rate me, please.
    Aug 11, 2009 | Tag Heuer Kirium Formula 1 Chronograph...
    Need Manual for Tag Heuer Formula 1. WAC 1110.JH1889
    Try Googling (Tag Heuer)(WAC 1110.JH1889)(manual) without parens.
    Jan 25, 2018 | Watches
    Tag Heuer 2000 Aquaracer Chronograph CAF1111 Watch Logo
    280 people viewed this question
    Top Tag Heuer Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
