Need to replace the rubber gas line
SOURCE: weed eater featherlite primer bulb won't fill with
Hello
From your Description and Depending on the OEM (Zama or Walbro) of the Carburetor it Sounds like a Bad Fuel Filter or the Primer Check Valve has Stuck and the Carburetor Requires Soaking and Cleaning.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.poulanpro.com/poulanpro/indexAction.do?id=default and Select Order Parts and Accessories. On this Page Select Illustrated Parts List from the Menu on the Left. Now Select the Manufacturer (Poulan/Weed Eater) and Enter the Model Numbers in the Boxes at the Lower Left of the Page.
I Require the OEM (Walbro, Zama, ect) and the Model Numbers Off the Carburetor. With these I can Locate a Breakdown of the Carburetor and Better Assist you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Fetherlight xt200 fuel line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
SOURCE: weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The
next time you run the trimmer and it starts to die, loosen the gas
cap. If it starts running again, then you know that it's a clogged gas
cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
SOURCE: Can,t prime fuel with primer ball on my weed eater
sounds like it has gotten dirt in it, flush lines and tank with brake cleaner, remove primer bulb usually 4 screws and clean under there too reassemble and try again fixes most of the time
SOURCE: Weed eater te 475 runs for a few seconds and then
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
