Honeywell T6575D1009 - Digital Fan Coil Thermostat; 4 pipe Auto Heat/Cool changeover, 3 speed fan with On-Auto Fan switch - Overview T6570 Series Digital ...
Honeywell T6575D1009 Thermostat. This item has been replaced by TB6575A1000, which is a functional replacement. See the suggested products field for a ...
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
The Honeywell CT87 thermostat is a normal round thermostat, not digital and may have a sub-base installed with it that has a two switches on it. One is for Fan (Auto or On)and the other is for Heat, Cool and Off. Make sure the Fan switch is in the Auto position and the other switch is in either the Cool or Off mode.
If you continue to get cooling, you have a short in the thermostat wire or a stuck relay in th indoor or outdoor unit. To test this, while the unit is running; remove the round outer ring on the thermostat by pulling it straight off towards you. You will find 3 slotted head screws that hold the thermostat to the sub-base. These screws are located at the 3 o'clock, 7 o'clock and 9 o'clock positions. Turn these screws counterclockwise with a small head screwdriver. They are held in place so should not fall and get lost. With the front of the thermostat removed from the base, the air conditioner should stop running. If the unit continues to run, you will need to have your A/C system inspected by a technician.
If in fact your thermostat is digital, look to see how it is mounted to its sub-base and remove it. If the system stops, you may have a bad thermostat or the Fan switch is in the On position. Hopefully this will help.
