Canon EOS Rebel XS 35mm SLR Camera Logo
A
Anonymous Posted on Jun 20, 2014
Camera won't shutter
The flash pops up but it won't take a picture (shutter).
Ric Donato
Level 2:
Novelist:
  • Canon Expert 232 Answers
  • Posted on Jun 21, 2014
Ric Donato
Canon Expert
Level 2:
Novelist:
Answers
232
Questions
Helped
87729
Points
291
So that any responder does not repeat steps you have taken, what have you attempted to do to solve this issue?
  • Turning on and off the camera sometimes will fix it.
  • If you are in AF mode and the camera cannot get focus it will not fire the shutter.
  • If it is in a low light area, reason the flash popped up, and the camera cannot find something to focus on it will not fire the shutter.
There are a number of things that can cause this, some nothing to do with an errant camera.
Cordially,
My nikon 5200 built in flash would not pop out
Here are a couple of things to check. First, what mode is the camera in? If it is manual or shutter priority, make sure the shutter speed is under 1/250 second. Second, if the ISO setting is very high, the flash might not deploy because it is not needed. What do your pictures look like? Are they properly exposed without the flash? Also, make sure that the flash is enabled in your menu and at the flash button to the left of the lens when viewed from the camera back. Check in the menus to see if it is in the command mode by accident.
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
2answers
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
2helpful
My camera is several years old. The flash stopped working. I replaced the batteries. Any ideas?
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
1helpful
Delayed Shutter, No Flash, and Menu Issues
Pls check your camera settings. Your shutter may be set to 10" (meaning 10 seconds). That is probably also why your pop up flash does not go up... because it feels that it will already get over-exposed pics.
To check if it is not a hardware problem, change your settings to Auto and try to shoot in a dark room.
NOTE: Please rate our help to keep this free service online
6helpful
2answers
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
2helpful
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Dark Picture
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Auto flash function not working in "P" mode...
I found the same problem, I am a memeber of a group and have just asked them. Should have an answer soon.
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
