Televison & Video Logo
Question about Panasonic Televison & Video
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
WHEN I INSERT MY VHS TAPE TO THE VCR IT EJECTS BACK...I DID IT MANY TIMES...BUT SOMETIMES WHEN I INSERT IT TAPE GOES IN AND TAPE RUNS AT HIGH SPEED WITHOUT PLAYBACK .SO UNABLE TO EJECT AND ALL PLAY PAUSE FAST FORWARD REWIND BUTTONS DOESNOT GIVE ANY RESPONSE WHEN PRESSED..SO I HAVE TO POWER CUT AND AGAIN SWITCH ON TO EJECT THE TAPE
Posted by Lasitha Pussella on
Christina Croucamp
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Posted on Jun 21, 2014
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
1helpful
Vcr ejects tape when i try to record.
is the erase protection tab removed from the cassette?
if yes there is a square hole on the back of the tape visible when you insert it.
put a piece of sticky tape over this hole and make shure it does not come loose.
it should record fine now when you insert it again.
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
When I insert a VCR tape, it automatically and immediately ejects. HELP.. :-)
I rather suspect a mode switch problem. Sometimes you can clean them with Servisol Video 40, but it may have be replaced. Check also the carriage (the bit that lifts the tape) for damage.
2helpful
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
2answers
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Open Questions:
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
