Hi Graeme Jackson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Hi Graeme Jackson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Xeroxhttps://www.support.xerox.com > en-us > article
Jan 19, 2021 - Resolve the Duplicate IP Address Conflict With Another Device on the Network. Manually Set a Static (Permanent) IP Address on the Embedded ...
Copytechnethttps://www.copytechnet.com > ... > Xerox
Aug 30, 2014 - This error code means your bustled Fiery or Creo network controller do not communicate with the machine. Check all cable from net controller to ...
Printcopy.infohttps://printcopy.info > code=027-452
Code: 027-452; Description: IPv4 Duplicate Duplicate IPv4 addresses detected upon startup. Causes: Remedy: 1 At the printer's Control Panel, press the Menu ...
RCA Universal Remote Codes:
For the RCA Universal Remote, there is a total eight different codes for RCA TV's and nine for VCR's. There are two different codes for cable boxes:
The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
The Toner Supply Screw Rotation Sensor detected rotation error within the specified period of time.
Remedy
[Related parts] R1.01 - Harness between the Feed/Drum Driver PCB (UN2/J225) and the Developing Motor (Bk) (M8/ J6011) - Harness between the Feed/Drum Driver PCB (UN2/J212) and the Toner Sensor Relay PCB (Bk) (UN42/J1430) - Developing Motor (Bk) (M8) - Developing Assembly (Bk) - Main Drive Assembly - Set-on Hopper Assembly - Feed/Drum Driver PCB (UN2) [Remedy] Perform the following in the order while checking whether the error is cleared. 1. Check that the Developing Coupling of the Developing Assembly is not damaged. 2. Check that the Developing Coupling of the Main Drive Assembly is not damaged. 3. Check/replace the related harness/cable, connector and parts.
By the look of it its an IP conflict with another device on your network trying to connect - turn of any other devices that may be conflicting and restart the device giving error then restart device that you are trying to connect with...
