The tv cannot be powered on. all I get is 8 blinking lights
SOURCE: The power light keeps blinking and it doesnt
the blinking power light is actually a diagnostic of a faulty part inside the set.
Here is the diagnostic info and which part you need to replace.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
if this set is still unedr warranty, please use the warranty to replace
the part. Else, have a professional install the new part for your
safety.
hope this helps.
regards,
voodoo
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
SOURCE: TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
SOURCE: tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
