Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Dishwasher pumps water in and out, but does not wash
I have recently moved my mother's Bosch Exxcel SGS4442GB/01 dishwasher into my flat. It worked just fine before the move, is all connected up, plugged in, etc, but while it pumps water in and out, it now does not actually wash. I think something minor may have happened in transit - despite my protestations, it was moved laying on its back. All suggestions welcome!
Posted by AliKat on
  • Anonymous Nov 06, 2007
    Our machine has the same problem - the water is taken in and pumped out after the program is finished, but the water is not being fed into the rotating arms to wash the dishes. Is there a pump in the machine that pumps the water up the the arms? Where is this and is it easy to change?
  • mad_oatcake Nov 11, 2008
    I have exactly the same problem but i'm not sure how to go about implementing the fix but with a SGS43E08GB/45. Can anybody help?
Anonymous
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Posted on Aug 13, 2008
Anonymous
    Champion:
  • 249 Answers
Air lock in pressure switch unlock it,remove little tube going to it and reconnect it check relay in motor
Posted on Nov 28, 2007
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
I have a Bosch Exxcel dishwasher which runs the drain pump constantly even with the door open and despite there being now water in the machine at the cycle wont start. I have checked the warer amtrix and...
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
Jun 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Mar 13, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch sgs43a32uk/01 dishwasher
clean filter outlet, pipe is ok ..remove stainless steal screws in side door it should be easy to fit seal then.
Nov 27, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
573 people viewed this question
Top Bosch Dishwashers Experts
peter gittos
peter gittos
Marvin
Marvin
Ekse
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
