Brother FAX-2920 Plain Paper Laser Logo
A
Anonymous Posted on Jun 21, 2014
BROTHER 2920 TONER RE-SET
IMY BROTHER 2920 IS STILL SHOWING A TONER LIFE WARNING AFTER I HAVE RPLACED THE TONER UNIT IS THERE A RESET I NEED TO DO TO CLEAR THE WARNING MESSAGE...?
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 20, 2007
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Anonymous
  • 78 Answers
  • Posted on Jan 21, 2008
SOURCE: toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
Anonymous
  • Posted on Jun 24, 2008
SOURCE: toner life
where and how to find the reset actuator?
Anonymous
  • Posted on Sep 23, 2008
SOURCE: HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Anonymous
  • Posted on Jan 02, 2009
SOURCE: Toner life end
Try this:
Open the cover, leaving everything inside. Press Options, then *00 to reset the fax.
If that doesn't work:
Open the front cover and remove the cartridge and drum. Turn off the fax. On the right-hand side of the cartridge, there is a round hole that is covered with a clear plastic or glass. Cover that hole up with tape, put the cartridge back in the drum, and put them back into the fax, and turn it back on.
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
How to replace in k
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
17helpful
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
6helpful
3answers
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
2answers
2helpful
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
4helpful
2answers
How do you change the drum on a Brother IntelliFAX 2920?
Open the front cover.Pull out the drum and cartridge unit.Unlock the toner from the drum with the blue clip.Take the new drum remove all the pacaging material insert the toner in the new drum.Replace the drum and toner unit back in the machine.While the cover is open,press the clear button.The machine will display "Replace drum yes or no" Select Yes.Close the front cover.
7helpful
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
2answers
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
44helpful
4answers
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Norman Weimar
Norman Weimar
k24674
