Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony grand wega KDF-60WF655 keeps shutting off and on
I will have to come back with more info
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Posted on Feb 01, 2008
Anonymous
  • 3 Answers
SOURCE: SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
This seems to be common problem with Sony projection tv. I have the KDF-E50A10 that lasted only 2 years. It's sitting in a corner now until I figure out what to do with it. I am not going to spend another grand to repair it!! Never Sony again.
Posted on Aug 02, 2008
Anonymous
  • 40 Answers
SOURCE: Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Posted on Mar 18, 2009
Anonymous
  • 261 Answers
SOURCE: Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
Posted on Jul 01, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Posted on Oct 21, 2009
Standard curve
can you put more info back on fixya so we can try and help you..so we need more that just standard cure..
if its about a tv then you must say.so put all info back up on fixya.
Dec 09, 2016 | Televison & Video
Someone setup my ipad mini with their info, how do I reset with my info?
You don't ask them to reset as new .Then put your own info This sounds a bit shady or give it back it's no good to you
Dec 29, 2015 | Apple iPad Mini
Accidentally erased my acct info can't get back my info is [email protected] pw nanarose help
First step would be to remove this question and re-post without your username and password!
Then contacting facebook help.
Good luck.
Mar 10, 2015 | Facebook Social Network
I want to back up all my info so i can upgrade to a new phone
Usually your info is already backed up into the cloud somewhere, ask the assistant who is helping you upgrade your phone about that or there should be a setting in settings that is labeled back up! hope i help!
Aug 04, 2014 | Samsung Galaxy Cell Phones
What is wattage on MR626T Welbilt Microwave (1997)
It will say on the door post or door or the back. I can find no info online
Nov 28, 2013 | Welbilt Microwave Ovens
My palm pilot battery died. When i replaced the battery all mhy phone #'s and calendar. were gone. Is there a way to restore them?
Hello.
Unfortunately, the only way to restore the address info and calendar is if you have been backing up your info from your Palm to your computer. Use the bluetooth (if you have) or connect the cradle to hotsync and transfer all your info back to your Palm.
Hope this helps.
Dec 24, 2010 | Palm Zire 72 Special Edition Handheld
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
How can i check the serial number on verify there authenticy?
mcdevito75 here, The serial number is the number off the movement itself. You"ll have to remove the back cover of the watch or have a watch repair shop remove the back cover and record this and all info on the watches movement. Any info on the back cover of any watch can help somewhat but you need the info off the movement itself for accurate info regarding any watch.
Oct 23, 2010 | Watches
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
