Uniden BC340CRS Base Scanner Logo
m
milton walker Posted on Jun 20, 2014
How can i find free codes for my scanner?
Are there free scanner codes available?
Sparks Tech
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jun 22, 2014
Sparks Tech
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
5783
Points
15
If by codes, you mean frequencies, go to http://www.radioreference.com/apps/db/
and choose your state. I think you might be able to find what you are looking for.
tip
How can I create a Barcode for Free in Microsoft Excel?
<p>Placing barcode equipment or other things makes it easier to keep track of them. Instead of entering a long number, a quick scan with a bar code reader eliminates keystrokes. There are many different types of barcodes. The most famous is the Product Code or UPC Universal, in almost all items sold at retail in the United States. The UPC format only supports encryption of the songs. Other formats such as Code 39 (also known as Code 3 of 9) support letters and numbers. <br /> <p><br /> <p>1. Find a free TrueType font to the desired shape of the bar code. For example, the Code bar code format is 39 different TrueType font packages available free. Use an Internet search engine and type "Code 39 TrueType fonts" available in a free font found. Some specialized formats may not be available for free as a result of copyright or other restrictions. <br /> <p><br /> <p>2. On your Windows PC, select the Start menu and click Control Panel. Within the Control Panel, click Switch to Classic View "and appearance of the panel. Find the" Fonts "icon and double click to open it. On the File menu, select" Install New Font. "This opens a menu dialog asking you to change the font to install. Navigate to the folder that contains the downloaded TrueType font file. Select the font and click OK when prompted to install it. The source of new bar code will be available in Excel. <br /> <p><br /> <p>3. Start Excel and enter "98765" in cell A1. This value is converted to a bar. <br /> <p><br /> <p>4. In cell B1, type the following formula: "= CONCATENATE ("*", "*")" A1 and press enter. The result should be "* 98765 *". Code 39 format requires an asterisk at the beginning and end of the text to be encrypted. Bar code format other will have different rules. <br /> <p><br /> <p>5. Change the font in cell A1, choosing a different font from the drop-down menu at the top of the screen in Excel. Under the menu "Home", scroll down to "three of the nine free" source and select it. The text in the cell will now appear as a barcode. Increase font with a minimum of 28 points, so a scanner can pick up the scanning needs. <br />
on Jun 26, 2011 • Computers & Internet
2012 F-150 5.0 THROWING P2096
Where did get the code, whomever ran the scanner should you what means. Anyone can buy a $29 scanner and it has the codes listed. you should stay away from people like that. The diagnostic port does not how a code or anything else. The port no more throws codes than your keyboard throws character on the monitor screen. The codes are OBD and are available online free..
2answers
Code p1421 for nissan versa 2009
where did you get code, if the person using scanner cannot tell what it means I would leave. I would not any confidence on that person and credibility questioned. All codes are OBD 2 and are available on lone for frees. Took about 3 seconds to find answer. Next type Code p1421 for Nissan versa into search box. You can type code pxxxx into search box and get answer. Anyone can buy a $19.00 dollar scanner and even comes with code list.
Hint:
https://www.autocodes.com/p1421_nissan.html
https://autoservicecosts.com/obd2-codes/p1421/
4helpful
2answers
6helpful
3answers
How to reset engine check light for loose gas filler cap
Just disconnect the NEG battery terminal for 10 minutes and the Code should clear. Or you can get a free scan at Autozone or Oreillys and they will use their scanner to clear your computer.
The advantage with the scanner is you will not lose radio station Presets or security codes.
How to avail free download?
go to the cannon web site and get it. here is the web site.
http://www.usa.canon.com/home
1helpful
How do i get the police scanner codes
There are many sources to buy the scanner frequencies, but if you'd like to get some free, follow this link to Radio Reference
Search on the state, city, county you're looking for and the frequencies will be available. Be sure to scroll down the page.
3helpful
3answers
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, ...www.bearcat1.com/free.htm - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices ...oregonlive.com/policescanner/...?/policescanner/police_codes.frame - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police ...members.shaw.ca/crazykid755/scanner - Cached
1helpful
I'm tring to find codes for a police scanner for henderson,ky.
RadioReference.com is the world's largest radio communications reference website, featuring a complete frequency database, trunked radio system information, FCC License assignments and callsign maps, 10-Code Lists, agency maps, files, downloads, links, and detailed agency information for most public safety, military, and local government communications.
Best of all, registration and access to all the data is free, however some special reporting features and downloads are only available to Premium Subscribers of the site.
that should solve your problem
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
