Mitsubishi LT-46144 46 in. LCD HDTV Logo
A
Anonymous Posted on Jun 20, 2014
What do I need to replace on my MITSUBISHI LT-46144 tv to remove horizontal lines
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 26, 2009
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Anonymous
  • Posted on Nov 29, 2011
SOURCE: Anyone have the actual lcd panel part/model number
Panel is a Samsung LTA460HH-LH4
Anonymous
  • 760 Answers
  • Posted on Apr 10, 2012
SOURCE: my mitsubishi lt 40134 is showing red horizontal lines...How can I repair?
Your panel is bad. Not cost effective to replace.
Anonymous
  • 32 Answers
  • Posted on Jul 22, 2012
SOURCE: how do I remove tv stand on my mitsubishi LT 52133
There should be screws or a push button around where it connects to the tv
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Misubishi LT-46149 solid red light
Your TV is on stand by., you possibly have power supply board problem or main board.. you have to call a service
Screen stuck on media play
Switch off TV manually, switch off power and remove plug and wait for sometime and retry.
2answers
Anyone have the actual lcd panel part/model number and maker for the Mitsubishi LT-46144
you can only get this part if you are a mitsubishi authorized servicer. not to mention, I think its more than the tv costs to buy
The picture on my Mitsubishi rear projection big screen has pink and green lines going around all of the images
you will need to ajust the convergence of your tv. there should be a "test" swich/feature that brings up a grid on the screen. ajust the horizontal and vertical of each of the colors until the lines become white. you will need to be more specific on which model you have if you need more detailed instructions. it should cost less than $75 to get a tecnician to come over to fix this.
I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio [email protected]
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
