OKI B2540 MFP Printer Logo
A
Anonymous Posted on Jun 20, 2014
Oki b2540 mfp paper jam remove toner error - OKI B2540 MFP Printer
4 Related Answers
Anonymous
  • 197 Answers
  • Posted on May 05, 2009
SOURCE: Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
Anonymous
  • Posted on Feb 12, 2010
SOURCE: OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX
Anonymous
  • Posted on Feb 25, 2010
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Anonymous
  • 503 Answers
  • Posted on May 18, 2010
SOURCE: I NEED TO INSTAL OKI B2540 MFP PRINTER ON MY
You can go here
http://www.oki.co.uk/support/printer-drivers/index.aspx
1helpful
MF F@X activities
Good morning my printer okidata B2540 mfp not work anymore because the scanner installed on my notebook windows 7, it prints, but lost all other functions. so ask for help. Att WGS
Put a new toner in, now says "paper jam"
There is little of paper in printer. Take the toner out and with very attention see, it must be in taht place, from where the paper going out, or that place from where taking paper, it can bee small paper.
Dear, Oki B2540 MFP my printer, has in memory a large amount of faxes received but not printed, due to exhaustion of the toner. I would like to know how i can eliminate the memory of the faxes not...
You cannot clear the fax memory as its integral with the main memory. The only way to do it would be to wipe the whole printer of its memory and start again. Its not worth it. Just let it print them!
1helpful
You can go here
How to replace a toner before it ends on oki B2540MF??
I know this may seem like an obvious solution, but have you read the manuel? If it's no longer in your possesion, you can download it directly from here:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Alternatively, here's a link which shows you how to do it:
http://my.okidata.com/oki-faq.nsf/FAQCentral/18FE0A954455318585257656004A3BE4?OpenDocument
Hope this helps. If so, please rate. Thanks.
OKI B2540 MFP .... Just in the process of setting it up. I have one problem: I have one telepone line that rings once for most incoming calls but for faxing purposes I have a second number on the same line...
You need to get an auto switch box such as the Command Communications Comswitch 5500 it was what is called distinctive ring and that if the function you need. You can plug in your phone, fax machine, answering machine, etc. You can get them from Office Depot, Office Max, Staples and such.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
4helpful
2answers
I´ve got a message on my oki C5510 mfp printer "Failed to get printer information - Check printer". I´ve checked all cables and everything is ok. The toner light and exclamation light staying lit...
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
21helpful
2answers
OKI B2540 MFP IS GETTING A FUSER TEMP ERROR, DO YOU KNOW HOW TO FIX THIS ERROR?
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
