Question about La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor
Sharp atomic weather station spc 1003, lost the instructions, how do you set the dyalight savings time?
Setting daylight savings time
5 Related Answers
sg1972
Glen
  • 225 Answers
SOURCE: Set the clock to DST
Try this link and follow the instructions.
http://www.lacrossetechnology.com/3143a/manual.pdf
Posted on Mar 26, 2008
Anonymous
SOURCE: I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Posted on Nov 23, 2008
Frank10ROM
  • 9 Answers
SOURCE: Resetting to daylight savings time.
The clock is searching for a strong enough radio signal from NIST station WWVB. When it can't lock on it, it gives up, moves the dial four hours, and goes to sleep to wait for better reception. Put the clock in a window facing towards Boulder, CO, overnight. (Radio propagation is better after dark.)
Posted on Mar 09, 2009
Anonymous
SOURCE: Atomic Clock Daylight Savings
Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
Posted on Apr 01, 2009
Anonymous
SOURCE: LACROSSE WT-3161 wall clock. Can't set to Pacific Daylight Savings. Keeps Resetting back to PST
See http://www.lacrossetechnology.com/3143a/manual.pdf Press the unmarked button for 1 second. That turns DST on and off.
Posted on Apr 11, 2009
My Termostat appears to be set to start at 7:45 am, however, the heat begins at 6:45, why? What can I do to correct?
You have to check the daylight savings which may cause 1 hour difference, your unit may not be automatically adjustable with the current time (daylight savings). Set your unit's time an hour later to overcome the problem.
Feb 05, 2018 | Cars & Trucks
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do you set the time on a c340?
Question: The time is not correct on my StreetPilot. How do I set it?
I think one of these 2 may help you.... --> Answer: The GPS unit acquires the time from satellites. Therefore, to display the correct time, the StreetPilot first needs to acquire satellites. You can then set the time zone and daylight savings time.
To set the time zone and daylight savings time:
  1. Press the Menu button two times.
  2. Select System Setup.
  3. Select the Time tab.
  4. Select the time zone and daylight savings preference.
Oct 23, 2010 | Garmin StreetPilot c340 GPS Receiver
Daylight saving time feature
Press
Function
71
set
key in date and time
set
stop
Mar 09, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Setting to/from daylight savings time?
Press the white button on the base of the clock,
Harry
Jun 19, 2008 | RCA RP-3765 Clock Radio
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor Logo
202 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
