Machine starts wash cycle stops after rinse and shows error code E1 what is the problem.
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
E1 is a time-out, something is taking too long.
If it starts the wash then it is filling ok, (but see later) so perhaps it's taking too long to empty? Check that the water is pumping out properly by removing the outlet hose and placing in the sink as it's emptying; if it's too slow the outlet hose may be blocked with fat etc. or pump blocked/faulty
I have simplified this, from your description are you saying it gets through the first drain cycle ok? If so I'd still check the outlet hose and pump, but also make sure its getting water in quickly enough by listening to how long it takes to fill. Please report back? (Also I assume if it's getting through the wash then the heater is working ok)
