Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Remote is lost need to fix converge problem
The color converge crosses need to be aliened to focus the tv set and i don"t have a remote so i need in structions on how to do that eather by the front control buttons or in the back with the little black box that says focus and screen and has two sets of ajustment screws bl gr rd
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Posted on Oct 24, 2007
premtech
William Rayburn
  • 934 Answers
SOURCE: multi point convergence
In the multi-point adjustment grid use the exit/status button on the remote to lock onto the cross-hair that you want to adjust and again exit/status button to continue back to moving the cross-hair around to another location.
Bill
Posted on Dec 01, 2007
Anonymous
SOURCE: where can i buy remote control for phillips 55pp9401?
You can access the Intellisense with any universal remote that has a settings button.
TV > Settings > Video > Scroll down to find Intellisense.
Posted on May 26, 2008
Anonymous
  • 38 Answers
SOURCE: Using Intellisense without remote
some of the universal remotes by phillips have but not all have the program inside the remote for it u have to look on the box u can allso call magnavox witch is the same thing and ask customer service if the have a universal remote that will do that for u i hope this hp some
Posted on Oct 13, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Magnavox 51" Projection TV Red Convergence
he is most likely trying to rip you off. You need to replace the convergence ICs. Theres a kit at the following link for your model that has both ICs and the 12 feed resistors plus step by step instructions to do the repair. Heres the link. this is the kit your model uses. http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
A convergence problem such as your describing can blow a fuse if you try adjusting it when the ICs fail. and its all centerd on the SSM panel the LSB panel wont be affected. Alot of TV repair men dont have a clue they just try to sell you some boards instead of repair the issue.
Posted on Feb 04, 2009
The red color will not lined up with the green and blue, its way to much red, can you help
You need to set the Convergence of the TV set.
Some TV sets have a Magic Focus on the front panel, if yours has this press it with the TV on.
If your TV does not have the Magic Focus button, go in to the menu and there should be an Advanced Setup option ether in the main menu or under the video setup menu. Then find set Convergence. You will need to be directly in front of the TV set and at the normal distance away (where you usually view it from) use the arrows on the remote to move the color i.e. green, red, blue so that it disappears behind the white + (cross). this must be done for all of the mentioned colors.
Feb 05, 2010 | JVC AV-48WP30 48" Rear Projection...
Lost focus.looks 3d. red double. cant focus on red convergence.
This is a very common failure on Projection TV2_bing.gif sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com.
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
724bcba.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
Tv out of focus
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 03, 2009 | Akai PT4298HD Rear Projection Television
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
How do i set convergance on my53uwx10B
you can go in through the back of the tv to set the focus you should be able to converge the tv from the remote.if not i would call a service tech and have them come and reset it for you.
Jan 21, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Apex GB43HD10 Convergence
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You should be able to move them up, down, left, and right.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
