Come across a really annoying problem within our household. We're with TalkTalk for internet, i'm on a PC connected via WiFi through a dongle on the network. There's also a TV that is causing the internet to drop (internet light go red) whenever the TV Is turned on. Fine with the TV off, the internet goes back on. Been trying to figure this out all day for a while now. Can't find a way to completely DISABLE wifi function on the TV settings. Just can't find it, read manual too.. I've been into the network settings on the TV and there's a few options to connect to the network - Wireless/Wired/WPS and some other 1. The option that is selected is wireless, but i've took all the config out and just put 0.0.0.0 for everything. I don't know if it is trying to connect to the wifi as soon as the TV is switched on, I presume so? So yeah, i've tried all the obvious, even tried changing the SSID and turning WPS off. I know the MAC address of the TV, i've also tried filtering the TV out of the router/gateway via the MAC address but I dunno if i've done it correctly. If anyone can fix this for me i'd appreciate it so much.. The router is a HUAWEI HG533.
Posted by Sam McKay on
John Sanner
    Scholar:
  • 143 Answers
Ok. (I don't know how much help I can offer since I'm in USA and you're in UK). 1) From what little I was able to look up, TalkTalk Internet is really small and has a lot of issues regarding on what it delivers to it's customers. 2) The HUAWEI HG533 Router... (from your description of the symptoms with your TV), seems functioning ok, just that the Bandwidth (Internet speed of your ISP-TalkTalk) is too slow to keep up with everything you want to do once you add the Video for the TV. IF you use the Internet cable from your router to the TV, you should have a Faster connection for internet reception (compared to WiFi. Minimum of N-Band on WiFi should suffice for 1 TV and 1 Computer. 5 Devices or more, I recommend a Better Router and Cable your Devices that need the Fastest connection for response, IE. 1-2 computers, TV or Blu-Ray device that provides content to your TV). Best advice - Inquire your Internet Provider about your situation, Possibly change ISP's, Make sure your Router can handle the Usage on WiFi and Cable connect that you require. I have been using a D-Link DIR-655 N-Band Gaming Router (broadcasts WiFI @ 65Mbps/sec, 4 cable connect Ports with 1Gbps speed) for several years now. I've got 2 puters and a Blu-Ray device cable connected, we WiFi our 3Cell phones, a Sony WII and 2 other puters for our kids. We pay a about $25 more a month for faster Internet speed, all runs rather well (Time Warner Cable Turbo, USA, total Internet cost is $65 a month, we don't subscribe to any tv or land-line phone, since we use cell phones).
Posted on Jun 28, 2014
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: Wireless connection fails: won't assign address
As ever starting with the simplest of solutions normally works, well spotted.
Posted on Nov 28, 2006
Anonymous
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
Posted on Apr 20, 2008
Anonymous
  • 59 Answers
SOURCE: My wireless name (SSID) and security settings keep changing on their own!
hi,
well i saw the problem u r facing
and the only soution for it is the upgradation of the firmware ....
i was facing the same one on my router and it got corrected ....
otherwise u can call the customer care no of the the routers company and they will give u the replacement
Posted on Oct 23, 2008
kakee
Michael Galve
  • 1269 Answers
SOURCE: XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Posted on Jan 06, 2009
Anonymous
  • 241 Answers
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
Posted on May 28, 2009
Firewire network adapter dongle and install it. where can i find this
Depends upon where you live. MY question is though, why are you not using the built in WIFI to connect to the Internet? It is there for the using. Unless there is something wrong with it, of course. Be advised, unless you have an Internet Account (via an ISP), or are near a free WIFI connections, just having an adapter won't get you connected to the Internet. It's not the same as putting up an antenna and receiving broadcast TV signals. Since we last talked, I looked into a Firewire network adapter. They don't seem to exist. The problem is that the 1394 standard never got up on its own two feet, as the USB 2.0/3.0 overwhelmed it. SO, if you are looking for an external WIFI adapter, you'll most likely need a USB dongle. Sites like Newegg.com and TigerDirect.com can assist you. You can even get wireless adapters at your local Walmart!
Mar 18, 2015 | Internet Computers & Internet
My jvc smart tv is displaying wifi dongle detected and is not connecting to my Internet and it keep showing on the TV is quite frustrating thanks
You can stop the display about the issue via ''settings''. To actually connect to the internet you need to enter your wifi security code. It should ask you for it, but it may only ask for it if you try to connect via the ''settings'' menu.
Dec 31, 2014 | Televison & Video
How can I add an external WiFi Donegal to a median life pad
WiFi dongles are developed for PC usage. A tablet, does not redirect internet info to or from a USB connector. For every USB device you need a driver and a program on a computer. As long as you don't have the programs or app for any dongle, no use to connect any dongle to any tablet.
Sep 09, 2014 | Computers & Internet
My luxor 40inch smart TV will not connect to Brightbox router viA wifi dongle? Please help
You TV cannot use a wifi wireless dongle. The usb port on your tv is for connecting a usb drive for pictures or movies. There is no place to load the drivers necessary for a wifi or bluetooth dongle.
Apr 02, 2014 | Computers & Internet
How can i conect my both pc via wi-fi.? Pls help.! Thanks
In the market wifi dongle will available for app. 750 INR. Purchase it and click on the button on dongle to search wifi available then connect to your wifi with password or some routers will allow to connect by pressing button on router. -www.surisurender.com
Apr 12, 2013 | Computers & Internet
Connectiong to the internet
to connect to internet , you can connect wifi via your own connection or a known one.... and just use the password and your on.... you only need to access your router webpage to figure out your wep passcode...
Nov 17, 2011 | Apple Ipad I-pad
I have bought an Acer Aspire One netbook from a friend. I also have a 3 mobile dongle but I just cannot get the netbook to connect to the internet. I have tried to go on the Live Update tab but it keeps...
The Acer Aspire netbook I bought has a switch on it to connect to the WiFi Internet G. If you want to use the dongle to communicate on the Internet, then first try to use the built in Wifi to install the driver for it.
Dec 26, 2010 | Acer Aspire One PC Notebook
I wanted to search the web on the compaq armada 3500 that i got and was wondering where the cable goes and if it even gets internet
hi yes you should be able to connect a wifi dongle via the usb port on the side for your internet connection, you would have to buy a pcmcia network card if you want network connection to internet through your modem, so if you have wifi router/modem then a dongle would be better..hope this helps
Jul 12, 2010 | Compaq Armada 3500 Notebook
I think i have a virus
This is probably not a virus. More likely a driver misconfiguration.
Try plugging the dongle only after your computer is turned on and windows has already started.
If this does not help, please elaborate on the type of the dongle? is it a wifi network card or a cellular modem?
Jul 05, 2009 | Canon Canofile For Windows Full Version...
Wifi Dongle
function PopupWindow(URL, WIDTH, HEIGHT){ var winleft=(screen.width-WIDTH)/2; var winright=(screen.height-HEIGHT)/2; day=new Date(); id=day.getTime(); eval("page"+id+" = window.open(URL,'"+id+"','toolbar=0,scrollbars=1,location=0,statusbar=1,menubar=0,resizable=1,width="+WIDTH+",height="+HEIGHT+",left="+winleft+",top="+winright+"');"); }
USB WiFi Dongle
Product reference: 11590 Here is some Technical data on your wireless adaptor. There is also a link at the bottom where you can download the driver for the operating system you are running.
" data-src="http://www.mobilefun.co.uk/graphics/rightarrow.gif" width="10" /> Description The USB WiFi Dongle easily connects your USB-equipped desktop or notebook computer to your wireless network for internet and file sharing. Desktop users can now join the network with the ease of a USB plug-in, without opening their PC cases, laptop users can enjoy the benefits of staying mobile-while connected to the internet.
By adhering to the 802.11g wireless standard, the USB WiFi Dongle is capable of streaming video and transferring large files across a wireless network. You will most likely need this if you have a bought a wireless ADSL or cable modem and wish to connect your PC to the internet or other PCs on the network wirelessly. The USB WiFi dongle is also compatible with all mobile phones and PDAs with WiFi connectivity.
Features:
  • Versatile use with Desktop PC or Laptop Computer
  • Portable, compact, pocket sized design
  • Compatible with IEEE 802.11b (11Mbps data rate).
  • Compatible with IEEE 802.11g (54Mps data rate).
  • Dynamic data rate scaling at 6,9,12,18,24,36,48 and 54Mbps for 802.11g.
  • Support wireless data encryption with 64/128 WEP for security.
  • Support infrastructure networks: Access point and ad-hoc network.
  • Supports WPA enhanced security.
  • Supports DFS/TPC for European operation.
  • Friendly user configuration and diagnostic utilities.
  • High speed USB 2.0 interface.
Technical data:
  • Chipset: SiS 163U.
  • Standards: IEEE 802.11b, IEEE 802.11g.
  • Frequency Band: 2.4GHz ~ 2.483GHz.
  • Data Rate: IEEE 802.11b, 1, 2, 5.5 & 11Mbps.
    IEEE 802.11g, 6, 9, 12, 18, 24, 36, 48 & 54Mbps.
  • Transmitter Power: 17 dBm.
  • Receive Sensitivity Operating at 11Mbps: -80 dBm @ 8% FER.
  • Operating Range: 100 - 400m, depending on environment.
  • Antenna: On board chip antenna.
  • Security: 64-bit or 128-bit WEP/WPA/TKIP.
  • I/O Interface: USB 2.0.
  • Size: 58 (L) x 23(W) x 9(H) mm.
  • Weight: 9g.
System Requirements:
  • Windows 98SE/ME/2000 and Windows XP.
  • Pentium 233 MHz or higher.
  • 32 Mb of RAM under 98, 98 SE, Millennium & NT 4.0 with Service Pack 5.
  • 64 Mb of RAM under Windows 2000 and Windows XP.
  • 100 Mb of disk space.
rightarrow.gifDriver Download To download the latest drivers for Windows 98 or higher click here.
Apr 14, 2008 | Computers & Internet
Computers & Internet Logo
124 people viewed this question
Ekse
Marvin
Marvin
