Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
How to remove brush cover on shark navigator - Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
2 Related Answers
Anonymous
SOURCE: shark navigator n22
What I tried and it worked for me is to losen the hose slightly from where it connects to the long plastic tube on the side to allow the little hole to show. What that does is to lessen the suction power a little since the problem is that the suction is too powerful on the carpet and the roller freezes.
Posted on May 22, 2010
xclubcar98x
xclubcar98x
  • 111 Answers
SOURCE: my brush won't turn on
Can you turn it by hand?
My bet is a belt broke or slipped off. Or it could be jammed.
Posted on Jul 05, 2011
I have the shark rotator vacuum and the brushes won't spin
Hello again Lois Victor,
Make and model number always help... Thanks.
If you don't have your manual...
find them FREE at
Shark NV750ANZ Owner Manual
or here..
Shark Rotator NV752 Owner Manual
or by going to
http://poweredliftaway.com/
AGAIN... hope this helps
Carnac the Magnificent
Jan 10, 2018 | Shark Vacuums
How do I change the belt on my Shark Liftaway
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Feb 22, 2015 | Shark Navigator Bagless Upright Vacuum
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
Stripped screw on shark navigator plate
drill the head down to the shaft of the screw then remove plate, remove remainder of screw if possible, fit new screw.
Dec 30, 2013 | Vacuums
How do I remove brush from the NV-22 Shark Navigator Bagless Upright Vacuum?
Remove the screws from the power nozzle and the cover can be removed to get to the brush
Oct 11, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
I cannot remove the brush roller on the Shark Navigator Lift-Away. It has thread caught in it that cannot be removed without actual removing the brush roller.
Hi, it's Ambrai from Crucial Vacuum.
Your Shark NV22 has small wheels underneath the head of the vacuum that need to be popped out. The wheels hide screws that need to be taken out along with the three other visible screws. Using a flat and sturdy object, pry out the wheels. After unscrewing all of the screws, you will be able remove the cover and access your brush roller.
While you're repairing your Shark NV22, why not replace your hose and/or filters? For optimal performance, it is recommended that you change your filter every three to six months.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv22&order=relevance&dir=desc
Ambrai Brown
Apr 26, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
522 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Muntejaya Ginting
Muntejaya Ginting
Richard Schabler
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
