SOURCE: Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
SOURCE: iPhone "Network Lost" message every 3 minutes!
Go - Settings/General/(scroll down to) Reset/Reset Network Settings.
Phone will turn itself off and on again. Et voila - no more annoying message saying "Network Lost"
Note: This procedure doesn't mess around with any of your other settings, applications etc.
Good luck.
SOURCE: HP-T4254 Samsung Plasma - Cracked Screen
This appears to be more common than Samsung lets people know. There isobviously a manufacturing defect. Same thing happened to my tv and it was only 4 months old. Samsung refuses to honor their warranty claiming it's physical damage...no kiding...there was a pop like a small firecracker going off inside the TV and the screen broke. You think think with this kind of catostrophic failure there would be physical damage? We're going after Samsung (BBB, FTC, small claims, etc.), if we can get enough people maybe go class-action.
SOURCE: Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
