Question about Sony RDR-VX555
Why does my Sony DVD recorder say the current disc is non-recordable. Replace with a recordable disc?
5 Related Answers
Anonymous
SOURCE: Discs I have recorded I get the disc can neither be played nor recorder, and it erases what I have already and already watched.
I have the same unit. Similar problem but mine does not erase the disc. It says disc error on almost all dvd that are store bought and kicks them out. Will play almost all of the ones I recorded on it and finalized. I must let a disc in it at all times or door will not open. Lots of bad stuff on the net about this unit. It is a lemon! Mine is out of warranty and sony wants $175 to fix. Saw some blogs where it was serviced 3 times and still not right. Buy a new one before investing in the unit you have as there are many gremlins in it! Sorry I cannot offer specific help but this is where I am at!!
Posted on Mar 11, 2008
Anonymous
  • 6 Answers
SOURCE: Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Posted on Mar 31, 2008
Anonymous
SOURCE: After recording the DVD player, wont play on any other player
You need to "finalize" the dvd you created - usually on the machine that you created it on. The SONY RDR-VX525 finishes recording, then you have to go to the system menu and follow the prompts to do the "finalize". As it's finalizing, it should the word finalize on the front panel display. It'll run about a minute or two and then just stop without telling you what it did. It should be ready to play on any dvd player.
Posted on Jul 22, 2009
Anonymous
  • 5 Answers
SOURCE: sony dvd rdr gx300 failure to delete discs
You can delete titles on a DVD+/-R, but it will not free up disc space. These are not "rewritable (RW)" disks.
To reuse discs, start with a DVD +/-RW. Be sure to format it "VR," not "Video."
http://esupport.sony.com/perl/model-documents.pl?mdl=RDRGX300
Posted on Jul 23, 2009
haas1703
  • 69 Answers
SOURCE: Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Posted on Apr 07, 2010
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Can't record on dvd+rw disc what kind of disc do I need Thank You
There might be a firmware upgrade to allow this I would use DVD-R for full compatibility however DVD+R media from Philips is increasing in compatibility with most NON Philips and Sony players.
Feb 25, 2010 | Pioneer DVR-225 DVD Recorder
Movie recording disabled
for disc (DVD) camcorder: this problem is due to high shock to camcorder. the recorder lens is moved from it's original place and can't record or access thereafter. you also can not finalize the disc (DVD). you have to replace the disc with new one.
you also lost your recording till the problem happened.
Dec 03, 2009 | Sony Video Cameras
Sony RDR-GX315 DVD 3 problem
sounds like your laser is getting weak. repair is usually not economical. laser is about 90% the cost of the unit. hope this helps if it still plays but not record. keep it as strictly playback unit.
Jun 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
I cannot write data from HDD to DVD+RW
The REC Mode of the recordings was set so high that there is not enough space on the DVD to make a recording. Cannot change at this point. For future recordings, switch to LSP or some other non-quality mode.
Feb 01, 2008 | Philips DVDR3455H/37B
Sony RDR-VX555 Logo
73 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
