Question about Moen & One Handle Tub & Shower Faucet
Moen - posi temp pressure balancing valve - Moen & One Handle Tub & Shower Faucet
5 Related Answers
Anonymous
  • 44 Answers
SOURCE: leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Posted on Dec 15, 2008
Anonymous
SOURCE: moen posi-temp for shower pressure
There is a little "o" ring in the shower inlet that is designed to collapse as the pressure increases, limiting flow. You can safely remove this and then have un restricted flow.
Posted on Feb 24, 2009
Anonymous
SOURCE: Moen posi-temp valve with little pressure
I have the same problem. Anyone know how to fix this?
Posted on Aug 09, 2009
snap101
snap101
  • 117 Answers
SOURCE: Temp control doesn't allow water to get hot enough
remove the handle and there should be a white plastic deal behind the handle that you can remove it's a temperature limit setter so people dont burn themselves remove it and you will get the full hot water
Posted on Aug 10, 2009
jpintore
  • 129 Answers
SOURCE: my replacement danco 88675 posi-temp cartridge
Call a plumbing supply house in your area, they will be able to help you.
Posted on Sep 27, 2009
Moen single lever shower handle gives only hot water
A bit more information is needed; is this a Moentrol or a Posi-temp valve? You will need to shut water down to the shower. If it is a Moentrol, it could be an issue with either the cartridge or the pressure balancing spool. If you are at least getting water, I am going to assume that it is a Moentrol.
You will need to turn water off to the valve. Pull the cartridge and examine as to whether or not debris is blocking the supply holes of the cartridge. If your valve has built in shut off screws, you can slowly turn water on to clear any debris that may be inside the inlet port. I typically use a piece of PVC to go over the valve body so that water does not leak between the wall and the shower. Again, just turn water on enough to start it flowing.
If you do not notice anything amiss with the cartridge, it could also be the pressure balancing spool. If that is on your valve, it will be a flat head screw about the size of a nickel. Water will need to be off for the removal of the spool as well. Again, you will be looking for debris that is blocking water flow.
If this is an older Moen faucet, you may just want to replace the cartridge while you have it removed. If it is a push/pull, it is a Moentrol. If you have to turn the handle for water to come out, it is a Posi-temp. In my area, the cartridges run from $20-$40. However, Moen does offer lifetime on their cartridges. Lately, I have had a few more hoops to jump through to get the replacement cartridges from Moen, but they are still very pleasant to deal with.
Oct 16, 2014 | Moen & Posi-Temp Single Handle Shower Or...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
No pressure.. Help
cartridge # 1222,i am not aware of the # for the puller, i just asked for a moen puller.be sure to get one that pull's pos'i cartridge's. because the older type puller will not pull positemp easy.and while you have cart out run water to flush valve body out.good luck!
Feb 01, 2010 | Moen 2352 Chrome Chateau Single Handle...
Aug 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
No water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Apr 09, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Help
Sometimes they are very stubborn. Get a pair of pliers or channel lockes and pull straight up. Try wiggling the and pulling at the same time. This is the only way it can come out so you just need to keep working on it. Good luck!
Apr 05, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen & One Handle Tub & Shower Faucet  Logo
134 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
