Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Sony Grand WEGA 55inch lamp out - Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Sony Grand WEGA KDF-42WE655 42
See owner / operator manual...if not available,can be downloaded
from our website....................T.
Posted on Feb 21, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
Posted on May 02, 2009
Anonymous
SOURCE: Sony Grand WEGA KF50WE610 50 blue hue blue dots
This model also has a paper filter for the Optic block that should be changed. No one ever said anything about it. shortens the life of the optic block if not changed.
Posted on Sep 02, 2009
Anonymous
  • 178 Answers
SOURCE: How to install the replacement lamp in my Sony
Two thumbscrews on either side of the tv on the lower part on the back(reach around the back on either side and you will feel them), unscrew them and the lower front panel will pop off. It will take a little tugging to get it to pop off but you will hear popping noise. then toward the center there will be another cover with a thumbscrew unscrew this and remove the cover, the bulb is located under this cover, then use the provided Allen wrench and unscrew the two Allen wrench screws holding the bulb in. Next insert the new bulb making sure you push the connector in firmly. Then re-assemble the unit.
Posted on Oct 10, 2009
Anonymous
SOURCE: reset lamp hours on sony grand wega
I just replaced the lamp on my Sony Wega 51 inch LCD Projection TV and it still doesn't work. Before I changed the lamp I was seeing the lamp indicator blinking green so I knew it needed to be changed. I bought a new one, as recommended by so many other people I saw online who were having the same problem, but after I installed it it didn't work. I turned the power on, you can hear it click and the power light turns green, then 5 seconds later the power light switches to blinking red. Someone help me please!!!!!
Posted on Mar 21, 2010
How do I reset the Lamp Timer on a Sony Wega KF-50WE620 TV?
Hello.
if you want to reset lamp timer on sony grand wega 50WE620...press menu on remote control then go to the setting you will find the setup button then press setup you will see the lamp replacement-start----yes and menu...
Thanks for using fixya
Caseytech
Jun 29, 2011 | Sony Grand WEGA KF-50WE620 Television
We have a 55inch sony rear projection TV and it is stored for the winter but its down to 10 below zero will this harm the tv if we leave it for the winter we live in alaska
Your TV is not a rear projection it is a DLP if had been a rear projection the answer would have been YES! Cold would damage all 3 of Tubes But you have a signal Lamp so TV should be OK.
Dec 08, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
When I turn my Sony Grand Wega Kf-50XBR800 on,
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety.
Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy.
Thanks.
Oct 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Changing the lamp in a Sony Wega KDF46E2000
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Yellow tint
The LCD green or blue inside the optical block is defective now. the optical block is the core of the tv (is the projector inside the unit "expensive"). make sure calling to Sony company and try to see in your particular serial # is covered under an extended warranty for this particular set. or at least ask them where you can get a good autorized workshop close to your area.
Apr 14, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA, Sound on, but no picture
Please replace Lamp in TV and I would recommend to buy Sony genuine Lamp from Sony Accessories, type mode number in search box and find Lamp in list, price would be approx $200
Dec 16, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
No Picture but sound
Your lamp has probably failed. It is a Sony XL2200 lamp
Oct 06, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Feb 21, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
