Question about Canon PIXMA MX310 All-In-One Printer
How to check & troubleshoot printer? - Canon PIXMA MX310 All-In-One Printer
Posted by Bernard on
Gradius2
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
The manual should contains such thing.
Posted on Jun 20, 2014
Jeremy Hoyle
    Champion:
  • 232 Answers
You can run a troubleshooting program from your computer, left click on the printer and go to the troubleshooter
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
My dell printer will not work with my dell cumputer.
First check the printer cable, unplug and replug the cabel in the printer and computer.
If it still does not work then reinstall the printer driver.
You can download the Dell printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=3A943AE039242E89E040A68F5B2854C9&journalid=803559AE24446852E040AC0A66E95D38&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=#Issue0_3
Jun 10, 2011 | Dell A920 InkJet Printer
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
My computer is not downloading my printer
You mean your pc cannot detect the printer?
Power cycle the pc
Power cycle the printer
try again
check if the software of the printer is already installed to pc
if yes then check how printer is connected to pc
wireless?
wired/ethernet?
usb cable
try checking these connections
then print again
this link below can help you check the troubleshooting steps specific to your printer
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=1843569&lc=en&jumpid=reg_R1002_USEN
Hope I help you a bit
Mar 28, 2011 | HP Photosmart D5069 InkJet Printer
У меня HP Photosmart 3210
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP Photosmart 3210 All-In-One InkJet...
Cбой сисÑ?емÑ? Ñ?еÑ?нил. Ð?оп&#
  • Connectivity :
Hi have a hp2610 keeps giving error message remove and check cartrages.this done then reads remove and check cartrage on right.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Sep 02, 2010 | HP Photosmart 2610 All-In-One InkJet...
I moved the printer to another room, then got a grinding noise when the printer warms up, this now happens when it prints as well
may be the cartridges inside the printer has been moved in his place , check it then check the cable connection between the printer and your PC..
ناوه‌ندی کۆمپیوته‌ری نه‌هرۆ
May 30, 2010 | OKI C5650n LED Laser Printer
My printout did not match to the scanned image
Try back. Pramerty printer are fixed in characteristic of the printer and in програме under the print. That parameters which is given from characteristic прнтера remain, but temporarily you may adjust printer from program of the print
May 29, 2009 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
145 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
