SkyScan 86742 Digital Atomic Wall Clock Logo
A
Anonymous Posted on Jun 19, 2014
Is there a transmitter for a SkyScan Clock available ?
The transmitter is not communicating with the clock, can it be fixed or can I buy another one ?
5 Related Answers
A
Anonymous
  • Posted on Sep 04, 2008
SOURCE: I have a87900 model skyscan,can;t get it reset after replacing batteries
http://www.skyscaninfo.com/content/
they have instructions online
Anonymous
  • 7 Answers
  • Posted on Dec 19, 2008
SOURCE: outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Anonymous
  • 3 Answers
  • Posted on Jan 15, 2009
SOURCE: outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Anonymous
  • Posted on Apr 12, 2009
SOURCE: skyscan atomic clock model no 88902
Instructions for setting the clock can be found at:
http://skyscan.info/content/index.php?option=com_content&task=view&id=57&Itemid=40.
Anonymous
  • Posted on Nov 23, 2009
SOURCE: my clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
How to fix clock
Do you have the manual with you?
Jul 06, 2018 • Home
2answers
How are the batteries replaced, in the transmitter first, then the clock?
The transmitter for your radio controlled clock is the atomic clock in your region, I wouldn't advise trying to replace the batteries in it.
I am guessing you are talking about a remote wireless sensor supplied with your clock! Put good quality batteries in this and place it next to your receiver (your clock) while it registers and then you can place it outside or wherever you want it.
7helpful
My clock is nort showing up the outside tempertute
3helpful
2answers
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
I have no outside temp. reading on my clock.
Remove batteries from the clock and the outside temperature transmitter. Put the clock and the transmitter next to each other, then install the batteries in both units. This should fix it. If not, you have a bad tempurature sending unit, or a dead battery in the sending unit.
2helpful
Outside temperature won't work
Also,
Outside temperture
3answers
Outside temperture
After changing the batteries on the outside unit, remove the batteries from the clock for a few minutes, then replace them. This will reset the clock to 'talk' to the transmitter.
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
