Briggs & stratton motor model 204412, type 0142e1
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
SOURCE: need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
SOURCE: I have a Coleman Model PM0545007.01 6250 W
Seems that your carberator maybe clogged at the jets. However, before you purchase a rebuild kit for your carberator make sure the fuel flow coming out of the fuel tank has a steady flow. I have seen where the fuel hole or line at the tank becomes clogged. If you feel the the fuel flow is poor grab a wire type coat hanger and clean out the hole and fuel line. Also, check for fuel filters, replace it if you have one on the genset.
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
SOURCE: how to set govenor on a briggs 10hp ohv
You should do an inspection of the governor linkage and spring before start, it should be in full fuel and move easily by hand.
Governors tend to not just go bad or even out of adjustment.
Is your real problem a clogged carb?
This would leave the Governor in full fuel and still starving for fuel.
If so remove carb, flush and clean the high speed jet adjust needle valve all the way in back out 1.5 turns and it should run normally again.
Hope this tip helps.
r/
David
SOURCE: oil to used for a briggs and stratton genpower 305
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
