SOURCE: H5470 built in microwave
sound like the door monitor switched has blown or shifted out of position if the switches dont operate in tandem when door is opened or closed it will blow the 10 amp fuse and kill the display they will need to be checked by engineer if it is monitor switch they are not expensive to replace.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
