Amp got wet and I dried with hair dryer. It works but can't turn it up loud enough to hear. It's an infinity 7 speaker, etc. on 03 spyder conv.
The only solution I found with a similar problem was to replace the amp - got a used one from a salvage company.
The wires under the seat and amplifier get a little wet and corroded and it causes the amp only work on certain speakers
Sounds like you have a wire shorting but not enough to blow the system. Check around where speaker wire goes through fire wall or where wire goes through the door jam or where wire goes into trunk, where it moves. Hope that helps.
SOURCE: Amplifier
you dont have to worry about that. i had the same amp in my 2003 eclipse which i replaced with an alpine amp and still works greak
SOURCE: i am trying to install new stereo in 2003 spyder eclipse
IF YOU GO TO WALMART AND BUY THE WIRING HOOK UP KIT THATS MADE JUST FOR YOUR TYPE OF CAR U SHOULD NOT HAVE ANY PROBLEMS.. YOU CAN DO THE AMP BYPASS, OR YOU CAN INSTALL YOU NEW DECK AND REWIRE THE SPEAKERS DIRECTLY TO THE NEW DECK.. HOPE I WAS A HELP GOOD LUCK KEITH..
SOURCE: 2002 Eclipse Spyder stereo not working after floor was wet
Remember the amplifier in a Spyder is under the passenger seat. So it could have shorted out.
SOURCE: my 03 eclipse spyder got soaked inside and now the
check fuses remove radio and see if it has a fuse on the back side also let it dry out for a while. if it still dnt work may need to replace it
