HP W2007 LCD Monitor Logo
S
Stella Chute Posted on Jun 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor turns on then goes off
When I turn it on seems to have power then seems to disconnect
goneforever.
Level 3:
Top Expert:
  • HP Master 14,531 Answers
  • Posted on May 25, 2022
goneforever.
HP Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263843
Points
66315
Hi stella,
old monitor. 2007 CCFL , most are dead NOW !
if the PC (not told) fails he monitor shows and error. "no signal" or no connection then warns you going to sleep or to power saver mode.
all do that, at PC Deathh. (VGA or DVI dead at PC out)
the PC and the monitor have power lights that go dead or change color or blink and all that matters first. did they fail? 1 or both.
if LCD dims or dies dead, the and PC fans heard to spin and all power LED show normal actions.
he CCFL tubes are dead ,as all did long agol
seems to me your ran for 7 years, and at 20,000 hours the tubes CCFL black lamps are dead. or dim or intermittent
some work only in a warm room, not cold
page 54 (means CCFL tubes dead)
Agency Regulatory Notices
C-2User's Guide
Materials Disposal
This HP product contains mercury in the fluorescent lamp in the display LCD (CCFL)
7 years is a good run
now buy new LCD with LED, 2011 and newer,
2010 is change over year, toss coin,or avoid them. and all older are no good.
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
2answers
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
My monitor seems to be busted, I dont know if it can be fixed. The problem is that when I turned my computer and monitor on, It said my monitor was on with the green light on the power switch on the...
On most Dell monitors there is a built in diagnostic check. Disconnect the VGA or DVI monitor cable from the computer and power on the monitor. If you see floating color bars then the monitor is not the problem.
Monitor turn off after a second
Try to disconnect the monitor and check if the message to connect the cable stays on the screen. I will need more description to solve this. Like Is the monitor's power ON and the display goes off? Is it that the display goes off after windows booting process starts?
1helpful
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
1helpful
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
1helpful
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
